Sensor question.
Old Oct 17, 2009 | 11:12 PM
the baPhoon's Avatar
Default Sensor question.
On a 94 z28 which sensor tells the PCM when to kick the fans on?
Engine temp or coolent temp?
Old Oct 17, 2009 | 11:15 PM
Black96transam's Avatar
its the sensor on the front of the water pump. coolant sensor i think.. engine sensor is in the side of the block..
Old Oct 17, 2009 | 11:25 PM
wolfen's Avatar
it should be the one on the driver side of the block, i forget what # cylinders its between....
Old Oct 17, 2009 | 11:33 PM
that one is between the number 1 and 3 cylinders.. thas the engine temp sensor. honestly man they about $7 a piece maybe a little more.. go ahead and change both.. haha.. be the best thing to do. that way you wont have to go back and change the other one.. and make sure you put teflon tape on em
Old Oct 18, 2009 | 09:13 AM
shbox's Avatar
The sensor in the water pump talks to the PCM. The one in the driver's side head goes to the gauge. All other information is incorrect.
Old Oct 18, 2009 | 01:36 PM
like i said its the one on the pump that tells the computer to turn on the fans... and the one in the block is the engine temp sensor..
Old Oct 18, 2009 | 03:40 PM
shbox's Avatar
Yeah, I was trying to back you up (since there were two other posts saying the opposite).
Old Oct 18, 2009 | 04:07 PM
thanks.. kinda read ya post fast and took it wrong.. sorry man
