A/C Delete
and i know ill have to cut a hole for the heater lines which is fine, i dont see why it cant be mounted on the outside if the bolt pattern is the same.
1. Cut box flush with Firewall.
2. Cut passage for Blower Motor to blow into the Heater Core(you will see what I mean when you get in there..)
3. Make a template out of cardboard, punch out necessary holes.
4. Cut Panel and bolt it up.
any input on how to remove it would be nice. do i have to remove the entire dash board to get this crap out?
merv, did you take yours out from under the dash or ho did you do it?
Good luck on the mod. It is worth the effort when you see how clean you engine bay is. Here is mine now that it is almost all done(valve cover is off so i could move the header to get the bolt loose for the lower control arms):
your car . deletion of the ac hurts the resale value .also the window defogger
uses the ac compressor to clear the fog off the inside glass when driving in
rain .
Well when it is already broke anyways it would sell as a non working a/c to begin with. Second once the cars are moded as much as mine or others that have any other work done to their cars besides exhaust and CAI it has gone to a different crowd of people when it does come time to sell these cars. Most of the time a person that is looking into getting a car for the strip they really dont car about if it has a/c or not. At least i dont. I have grown up with 60's and 70's cars so a/c isnt that important to me and i live in southeast texas where a/c is really needed. So not everyone looks at it as a resell pro/con
