***NA Heads/Cam B-Body Record - 11.31 @ 119.7
When the engine is still making more power before the shift than after the shift, you're not shifting too high.
In answer to the question about the 10-bolt/spool: Yes, stock 10-bolt (8.5" ring gear, not the smaller 10-bolts that F-bodys come with). Strange spool. No sense in tearing up a posi unit when all we want to do is go straight
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I would imagine with that weight and those times he has tried tons of shift point and tire combinations before settling on what he is doing now...even though I too can't wrap my mind around the benefits of spinning a stock intake, 22x cam LT1 that high.
To lend input to the shift point subject and understanding, it's not the shift point rpm per se that gets you, it's the drop to rpm. Our cars weigh alot and if you drop below your torque band and don't have a good run at the next trans gear ratio, you don't carry the momentum and it slows the car down. My car is very similar to Pat's (I did both chassis's) and also shift at the rpm Pat does. Pat gathers information nearly every run and knows what to do with it. I suspect/predict he may be headed for 11.0's real soon.
#35
A very good example of a car set up right for the 1/4 mi. Not deminishing the AI top end, the 60' time, track conditions and DA being significant contributers to the ET.
B-body yanking the front end is stout ;-)
#36
Impressive results, just goes to show what you can do with these cars! I don't care that they are heavier than an f-body, and anyone yanking tires in a b-body is my f-in hero!
-SS
-SS
#38
The MPH says he will go faster yet. He used to run that ET a few MPH slower on a 150 shot of juice.
Notice how long rails are??? That is because they are using leverage to keep the nose down rather than weight. Why don't you look up the wheelbase difference f-body to b-body.
#39
#40
Damn cant wait to get my heads...I already have the LE 2.2 Cam just need some badass heads.Maybe you guys will be reading about me lifting in my wagon next yr lol!Hey mike harris i was curious what parts were taken off or replaced with aluminum parts to lighten up that bbody?driveshaft?bumper support?
