Optispark help!!!
Old Oct 22, 2009 | 02:20 AM
DatDude512's Avatar
Default Optispark help!!!
I took my camaro 2 the mechanic because when i'm driving and make a stop the car will turn off then when i turn it on it hesitates 2 move. They did a diagnostic test on it and they said that it needs a optispark and a water pump. Could those things be the problem with the car? And is the optispark expensive 2 fix???
Old Oct 22, 2009 | 02:29 AM
gregrob's Avatar
Yes and yes.
Old Oct 22, 2009 | 02:47 AM
whytryz28's Avatar
Originally Posted by gregrob
Yes and yes.
Lol
There not to expensive to replace nor hard either. I lifted one side of my car in the air enough enough to get under it. Took me a just under 3 hours start to finish (tools put away) to complete it.
Old Oct 22, 2009 | 03:06 AM
gregrob's Avatar
"Expensive" can be a relative term I suppose. ~$300 for an OEM unit and $500+ for a quality aftermarket unit is "expensive" to me.
Old Oct 22, 2009 | 07:32 AM
koolaid_kid's Avatar
Costs:
OEM Opti from thepartsladi on fleabay - $260 shipped.
Waterpump from Autozone - $70 plus shipping
Other items needed:
Gasket sealer for wp gaskets (2)
Thread sealer for wp bolts
Antifreeze to replace lost coolant
Rented harmonic balancer puller
Silicone sealer for Opti cap
Loctite for Opti rotor screws
The last two items are important, and will probably not be done by a shop, only by yourself.
This is reusing all existing hoses and clamps.
And if it is your first time, do not expect to be able to do it in 3 hours. It just ain't gonna happen. After you've done it a time or two, probably. Allocate an entire day and have a vehicle/friend standing by to get the parts you forgot to pick up.
Old Oct 22, 2009 | 08:00 AM
Pampered-Z's Avatar
Replacing the opti is not actually difficult, but there are allot of parts that need to be removed taking time, so the labor cost is high. If you have average skills you'll save allot of money doing it yourself.
Use the link below for details on what you need to remove. ( use the cam removal/install, so they details what you need to remove the WP and Opti ).
http://shbox.com/1/how_tos.html
Old Oct 22, 2009 | 01:37 PM
rat93's Avatar
ya man its pretty simple you got it, just pay attention and shbox's website is the bible
Old Oct 22, 2009 | 02:32 PM
Jazz-LT1's Avatar
Autozone has the optispark for around $175.00 , it is a Remanufactured unit, but it also has a limited lifetime warranty. I have replaced mine 4 times under the warranty when the water pump leaked, I drove through water, etc. I've never gotten a bad unit either. It does not come with a cap however so you could purchase an MSD cap if you like.
Old Oct 23, 2009 | 09:13 AM
ALEXZ28's Avatar
o reilly auto parts sells them for 129.00 with out C & R
Old Oct 23, 2009 | 09:56 AM
RamAir95TA's Avatar
You don't need a harmonic balancer puller. A simpler, cheap 3-toe puller will pull off the pulley.
