Stock rods with forged pistons yes or no
My buddy is on a budget and is only putting in forged flattops for spray and adding arp main studs and rod bolts. But he is wondering if the stock rods will be able to handle the abuse of nitrous with a LE2 package. Its a automatic with a 4.10 gear if that matters. If the rods wont handle the abuse what rods can he throw in there on the cheap end but quality? if any
thanks, Tom
thanks, Tom
thanks, Tom
thanks, Tom
I would go with a cheap I beam. than arp bolts. The stock crank will handle lots of power, I would build a motor with no weaker link.
There are several companies with cheap rods. Look at summit, jegs, other supporting vendors listed on the right side of the home page. If he is roughly 400rwhp and than a 150-200 shot those rods will be the thing to go first.
Im using stock rods and run a 400+ rwhp LE2 set up and plan on sprayin 200+. Im not worried about the rods.
Actually how many rod failures have you ever heard of??? Not many at all & I cant think of any off the top of my head at the moment. All you hear about is the stock bolts stretching and causing bearing failures.
A couple things popped into my head at first thought. Stock rods are press fit and will cost approx. $10 a rod to press pistons off/on, plus the cost to resize them and any clearancing needed on the sides of the rods as well, plus you are limited to 3/8 bolts. It's a little more up front, but worth it to go with a floating rod with 7/16 bolts for extra strength.
Strictly talking about the strength of the rod though, the stock rods will hold up fine as will an aftermarket I-beam.
http://www.ohiocrank.com/hbeam_rods.html
Check these guys out. you can get some excellent rods with ARP harware included. This is what I will use when I decide to build my new motor.
If you're going to all the trouble to replace pistons, you'd might as well invest in a decent
set of rods and fasteners. At least that way, you won't be tearing back into it again
because of a spun bearing.
I am running forged pistons on my reconditioned stock rods. Just upgraded to ARP bolts and I think it should be fine. I am not gonna spray any more than a 125 shot so I don't see a problem at all.
