LE1 Heads LT1 11.6's with a 6 speed. Video inside.
The very last run I had which I didn't get recorded, I should have hit 11.51. It is explained in the end of this video why I didn't get it. Do you guys think I can get mid 11.4x? Also I hit high 1.5s 60ft constantly, you think I can hit a low 1.5? I'll take any help.
I'm not sure if clicking HD will make it clearer or not. It will take a little longer to load though. Here is the video. Oh yeah if you have a youtube you are more than welcome to leave any comment whether good or bad. Thanks again.
http://www.youtube.com/watch?v=cmZ0-0cqoYA
sweet times man, congrats
I had a friend that ran the LE1 heads with a cc306 cam, he made 10-15 less power across the board vs the three other LE setups i built with LE cam or a BRE cams. You might think about swapping cams over the winter too, i think you would pick up some hp. FYI
LE1 heads are killer pieces for the price. They keep impressing me more and more. To be honest I was searching your sig to see what size shot you were running .
I also suggest swapping from the 306 to a custom cam .
very nice run, your driving the **** out of that car. any weight reduction done? what was the DA?
oh next time you make a video you should lower the music during the run so you can hear the car/shifts.
