LE1 Heads LT1 11.6's with a 6 speed. Video inside.
Well to be honest. I thought I had enough gas left in the tank. Apparently I was wrong. I'm an idiot. Yes I have a launch controller. If I was to turn down the music you would be able to hear it better. I think I cross the line at 6200 maybe.
Nice runs
Man there's a bunch of fast 6-speed 355" LT1s showing up all of a sudden, I'm loving it!
Time for me to make it back to the track so I can be one of the many mid-11 sec, 350-355ci, 6-speed cars too
Nice job, don't change the cam too quick, remember I ran 11.20@120MPH N/A with a very similar setup, (LE2's, CC306, 355 and an auto) but that cam loves some n2o too. Good luck and nice times. Clint
#32
In a couple of weeks I am going to try to hit mid 11.4s with the m6 before I switch to a TH350. Quick question. When I do install the TH350 it will only have a stall of 3600(Circle-D) because I will be using nitrous. If I am only racing all motor will this lower 3600 not be able to beat my m6 since the stall is not the recommended 4400 for all motor racing?
#35
Great times I'm glad 11.50's are attainable on the set-up I am going for...So out of curiosity, seeing as I have a T56 car now, whats the deal with no lifting these things with a good clutch, good rear, and radials? Is that a no no on a stock tranny at his power level as I saw you werent no lifting it...Just cause that will cut a tenth or to out right there... And you look like a bad *** doing it...
#37
