Need some help...
Old Nov 2, 2009 | 11:49 AM
tigersfan555's Avatar
Default Need some help...
I don't usually post anything since I am normally able to find what I'm looking for through searches, but I could not find what I needed today. I'm not sure how to explain this, but whenever I get on the gas really hard it seems as if I don't go anywhere. I thought it had something to do with my clutch hydraulics or clutch itself at first because I would notice it when I would shift to 2nd and 3rd at very fast takeoffs. Now I have noticed that it does not have to be during shift. I get the problem if I am just cruising in 2nd and get on it really hard. It almost feels as if I am slightly pushing in the clutch. The rpm's are high but I don't really go anywhere. It is not as though it is completely out of gear though since it does still go some.
I am not a mechanic and not great with cars, so excuse me if I am doing a horrible job of explaining.
All of this started after I did a transmission swap from an automatic to a manual. In the process, I purchased a brand new spec 2 clutch and an aluminum driveshaft that I installed during the change. It was a used transmission and I installed used hydraulics at first. I have now reaplaced the entire hydraulic assembly with one of the prebled units from GM, but I am still having the problem.
Any help would be greatly appreciated.
Old Nov 2, 2009 | 11:59 AM
94Z28rag's Avatar
New flywheel? It almost sounds like the clutch is slipping...it's something in the drivetrain.
Old Nov 2, 2009 | 12:02 PM
ohhh... Forgot to add that. I installed a new aluminum flywheel with the change. I also installed an adjustable torque arm with a new tranny crossmember that relocates the mount to the crossmember.
Old Nov 2, 2009 | 12:11 PM
fleetmgr's Avatar
If rpm goes up but the car doesn't accelerate, then the clutch is slipping.
Old Nov 2, 2009 | 12:58 PM
Thank you for the quick responses. I guess I will have to pull the tranny back out again. It has a brand new clutch and throwout bearing on it though. What should I be looking for when pull the tranny?
Old Nov 2, 2009 | 01:13 PM
airfix's Avatar
Did you properly break in the new clutch?
Old Nov 2, 2009 | 01:15 PM
94Z28rag's Avatar
My break in for Spec stage 3 and flywheel was 500-600 miles of all around driving. Never had a hiccup then or now.
Just FYI
Old Nov 2, 2009 | 01:29 PM
the_merv's Avatar
Veteran: Air Force
Do you smell anything along of the lines like hot brakes?
Old Nov 2, 2009 | 02:21 PM
I broke in the clutch for about 100-200 miles of light driving and started gradually getting on it harder for another 100 miles or so. I probably only have about 300-400 miles on it at this point.
I have not noticed any kind of unusual odors.
