Victor intake for LTx
-SS
Hope this helps. You will also need to mod the Intake or heads as the bolt holes are different.
If you're going to spend the time and money on a single plane, Id do an accufab TB. Dont use an elbow or stock style TB, the turns the air has to take is lost power. You'll get more power dropping the air straight in as opposed to running through an elbow. Just my .02.
-SS
-SS
OP: Just about any 'race' type machine shop should be able to covert your heads. I had a local guy convert my heads and charged me $200 for the work. Dont understand how some of these guys get as much as they do to do that work. Also, my local guy, he's well known for being very expensive so if he's charging $200 its really not alot of work. That was welding up existing holes and drilling, tapping the new. GL man.
-SS
I am planning on running a Vic E Intake with a Edelbrock low profile elbow, 90mm TB, and 22lbs of boost.
Post pics of it tonight.
Sweet, which one are you moving too? So you're doing away with the elbow setup?
You guys will have to let us know when you're coming to Crandall again.
I will be hitting Crandall for sure. I love that track! You will get a pm if we go.
T
