Where to find LT1 clutch master and slave???
Old Nov 3, 2009 | 06:28 PM
ss.slp.ls1's Avatar
Default Where to find LT1 clutch master and slave???
Where to buy an OEM (or suitable replacement) LT1 clutch master cylinder and slave cylinder, including the braded steel line?
If you can't get OEM anymore, what is a good replacement brand?
Old Nov 3, 2009 | 08:08 PM
porksoda's Avatar
Call Scoggin Dickey. Jesse over there has everything.
Old Nov 3, 2009 | 09:19 PM
tbag_skywalker's Avatar
I believe WS6Store.com has full prebled OEM master/slave assemblies including the braided steel line, resevoir, and resevoir hose
Old Nov 4, 2009 | 07:46 AM
the_merv's Avatar
I thought you needed the other kind..
Old Nov 4, 2009 | 08:30 AM
old93camaro's Avatar
he is the ws6 site wheer the slave is
http://www.ws6project.com/user_stor/...oducts_id=1208
Old Nov 4, 2009 | 10:26 AM
ss.slp.ls1's Avatar
LOL, I do, but I still have to DD this LT1 engine until I can get the LSx swap done. This will be the third clutch I have grenaded in one year since I put the new engine in. Each time something in the clutch disk snaps or shatters. I know power and my driving habits have something to do with it, but I feel like something else has to be contributing to it.
Old Nov 4, 2009 | 10:44 AM
the_merv's Avatar
Was everything installed properly..as in everything bolted in to spec..?
Old Nov 4, 2009 | 10:57 AM
ss.slp.ls1's Avatar
Yeah, last clutch I installed was a Zoom Kevlar clutch, torqued everything to spec, had the flywheel resurfaced, installed a new pilot bushing, broke it in properly for the suggested 700 miles. I do beat my car daily, but I figured it was last longer than 2 months.
I looked at the pilot bushing when I removed the clutch last night, and it looked like the inside diameter had been enlarged, like the inside had been ground away. That's why I think the inside of my clutch disk shattered. I don't know what's causing it. Every time I break a clutch, it's the inside of the clutch disk that brakes.
Old Nov 4, 2009 | 01:49 PM
the_merv's Avatar
Bronze Bushing?
Old Nov 4, 2009 | 01:50 PM
ss.slp.ls1's Avatar
Bronze Bushing?
Looked like it, but I don't know the exact material, cam with my Zoom clutch kit.
Old Nov 4, 2009 | 01:52 PM
the_merv's Avatar
Well they make a shitty Kevlar one too..
I have the Bronze one in my car, works fine at the moment.
Old Nov 4, 2009 | 01:54 PM
946spdz's Avatar
Had problems with my dual kevlar too, starting slippin like right away
Old Nov 4, 2009 | 01:56 PM
ss.slp.ls1's Avatar
Mine never slipped, actually it felt really good, held really well too. I like it a lot more than the orgainic stock type of clutches.
Old Nov 4, 2009 | 02:33 PM
the_merv's Avatar
That's one good things about the LS stuff..there is alot of aftermarket to choose from. Look into the LS7 Clutch when you get your stuff..it holds pretty damn good.
Old Nov 4, 2009 | 02:56 PM
946spdz's Avatar
yea i dunno what happened im just gettin a mcloed disk now
Old Nov 4, 2009 | 03:17 PM
ss.slp.ls1's Avatar
I am. SDPC has a good price on them.
Old Nov 5, 2009 | 12:22 AM
madhatter's Avatar
I picked up a stock setup prebled at the dealer. My cost two years ago was $138. I am sure SD can get you an awesome price as well. As far as going through clutches, maybe your input shaft has excessive play?
