355 suspicion
or pull oil pan and do the same..... compression wouldn't tell you crap cause it'll be the same regardless of bore.... and yes if it is bored .030 with a 3.48" stroke crank (stock) then it's a 355....
Most likely the blower cam is still in there since removing that would be more intrusive than simply stripping an air pump or TB
Checking compression would tell him that. If it's the same then obviously the only way to tell is a bore check.
obviously there's no way to check for it being a 355" other than bore check, but it'll tell him about his 'extra power' possibly.
Just going by the butt dyno is useless, you need to take it to the track or strap it to some rollers to see if anything was done to it.
I would have.
Either way a compression check can possibly tell him something. Not ci but that something could be rebuilt/built.
heads can also raise the compression. so it could show some head work is possible too.
You built a slower 355, therefore his is slower?
Butt dynos mean nothing?
355s mean nothing?
Yeah, I disagree on all parts.
Just cause you built yours a certain way doesn't mean his previous owner did.
Butt dynos mean nothing? They might be minimal and placebo, but he also says his car IS FASTER than other comparable cars.
And a 355 DOES mean something. Cause it could be a high compression or low compression motor. Clearly it's important info to him.
Why is everything about your car? This thread is about his possible 355 and how it may be faster because of how it was built. Stop trying to relate everything to your car.
