Bad day at track...
Old Nov 8, 2009 | 08:01 PM
SS MPSTR's Avatar
Default Bad day at track...
I was at the PSCA Finals in Fontana on Saturday doing hits all day on the car in two separate classes. The car was doing pretty well, while still getting it dialed in, and on the sixth run I dump the clutch and snap! A 3.5" IEDL aluminum drive shaft becomes a donation to the metal yard recycle center. Luckily I had installed a safety loop a long time ago and it saved a ton of damage.
Cliffs: if you race on MT/Hoosier/GY ET type tires or slicks, install a $50 metal DS safety loop.
I'm going to a Denny's chromoly steel unit after this.
Picture on one of the runs...street twin clutch is taking some practice to get right.
Old Nov 8, 2009 | 08:24 PM
SPEED#1's Avatar
Pics of the driveshaft and where did it break? Nice launch too.
Old Nov 8, 2009 | 08:27 PM
SS MPSTR's Avatar
I have not removed it yet, but it is shredded right where the tube meets the joint right behind the transmission tail shaft.
Tireburnin's Avatar
That is a clean looking car.
Any pictures of the damage to the driveshaft? (I love seeing twisted driveshafts)
Old Nov 9, 2009 | 10:06 AM
StealthFormula's Avatar
Driveshaft loops are a must, I can't believe I waited so long to get one.
BTW, sharp looking SS!
Old Nov 9, 2009 | 10:14 AM
Elliott's94Z's Avatar
Stories like these made me throw a safety loop on mine. Sorry to hear but at least you played it safe. Good luck!
Old Nov 9, 2009 | 03:21 PM
Wicked94Z's Avatar
damn man, last week it was the 12 bolt... you got a pm coming about the psca meets
Old Nov 9, 2009 | 03:25 PM
T/ALT1's Avatar
What did you run before it broke?
Old Nov 9, 2009 | 03:31 PM
PewterScreaminMach's Avatar
x2? Good thing you had that safety loop. They don't prevent all of the damage from what I've seen, but enough to make it MORE than worth the small investment and 15 minutes of install time.
Old Nov 9, 2009 | 04:15 PM
Colin91Z's Avatar
x3
Car looks awesome btw
Old Nov 9, 2009 | 04:44 PM
LT1's Avatar
LT1
Looks good pulling the fronts!
Old Nov 9, 2009 | 08:32 PM
SS MPSTR's Avatar
11.75 @ 118, 1.71 sixty, 2300 DA, 3598# raceweight.
Old Nov 9, 2009 | 08:37 PM
SS MPSTR's Avatar
Thanks...even if it is an imposter?
Old Nov 9, 2009 | 08:38 PM
SS MPSTR's Avatar
Yep...twisted 33 spline axles, then the fragged diff, now the drive shaft...don't tell me what's next.
Old Nov 9, 2009 | 08:39 PM
SS MPSTR's Avatar
Originally Posted by Colin91Z
x3
Thanks man...gotta keep the LT1 look lookin' good.
Old Nov 10, 2009 | 10:41 AM
Haha I need to look closer apparently, let me refrase...that is a sharp looking Z!
Old Nov 10, 2009 | 10:47 AM
T/ALT1's Avatar
Not too shabby, the mph shows you are making HP but you need to work on getting the 60'-330' times down and the et will drop drastically. What gear are you running b/c those M6 cars need 4.30-4.56 or lower to leave hard. You also need a little wheel slippage so u don't break so many parts. LOL Goodluck Clint
Old Nov 10, 2009 | 11:13 AM
SS RRR's Avatar
Village Troll
Poser! If only Edgar Allen Poe could set you straight...
Old Nov 10, 2009 | 11:23 AM
quicksilver383's Avatar
Man I did all that damage w/ my ST except the d.s. but it's a steel one, Denny's NR to be exact. Are you running a 12 bolt and what gear? what rpm did you lunch it, I mean launch at?
Old Nov 10, 2009 | 11:19 PM
SS MPSTR's Avatar
Thanks Clint - I appreciate the advice from you. I'm already thinking about a 4.56 gear with an LS1 PCM conversion so I can spin the motor a bit higher. A little give at the line will surely make my transmission live a little longer too.
