From "cc 503 install help" to a full rebuild:)
Old Nov 10, 2009 | 11:23 PM
clwz28's Avatar
Default stall
It is the high stall,they say 2100,but I had a friend with one in a 95 ta and it stalled about 2300,you can get one off ebay for about $90 + shipping,just look up 700r4 dacco.The late 700r4 uses the same converter as 93-97 4l60e,I had one In my v8 s10 with about 380 rwhp and drove it on the street all the time,it also ran high mid 12s on shitty nitto tires.
Old Nov 10, 2009 | 11:31 PM
WARDOG's Avatar
Default stall
ok cool .Tomorrow im gonna head out and inspect the engine that i found that looks to be rebuilt. What should i look for on the engine to identify if its been rebuilt? One thing i saw was the head were silver shiny when i took off the oil cap and new ac delco plugs , new seals and no oil at all on or around the engine.
Old Nov 11, 2009 | 12:43 PM
buzz12586's Avatar
Yea whatever you do don't put that 2000 stall in the car. I have an Yank SS4000 converter in my cc503 cam only car and I love it. My 10 bolt however did not.
Old Nov 11, 2009 | 09:13 PM
WARDOG's Avatar
Default converter
Ill leaning towards the dacco 2200-2400 stall for now. Im gonna order the com cams 503 and springs , Jegs 8.5mm wires , energy suspension motor mounts. Plan is to go around town to transmission shops to ask who sells the dacco converter. Gonna go and inspect further that camaro engine . If it looks good and turns im gonna pull it and inspect it before i buy it. The motor is form a 94 camaro and i have a 97 ws6. Parts different are timing cover , cam and WHAT ELSE I GOTTA SWAP ?
Old Nov 28, 2009 | 10:57 AM
WARDOG's Avatar
Default Fresh rebuild
Well after thining it over and overi decided to freshen up the lt1. But i rain into this 4 bolt main at the local LKQ and decided to fresh it up. Well brough it home and inspected it seem to be low mileage motor and found out when i popd the oil pan that it was 4 bolt vette engine. Started to disassemble it and there was no ridge at all on the cylynder wall and i could see clearly the cross haching on the cylinder wall. Here are some pics as of today
Old Nov 28, 2009 | 01:15 PM
RamAir95TA's Avatar
Going with a 2400 stall is a waste of money, IMO. You should run at least a 3200.
But good luck with the motor build though.
Old Nov 28, 2009 | 10:00 PM
ADM's Avatar
ADM
Originally Posted by StealthFormula
Forget you saw that 2000 stall....That cam needs a 2500 stall minimum for the car to drive properly. Otherwise it will not have good brake vacuum and will pull the brakes at lights. Been there done that with that same cam myself. I would recommend something like a 3200+. BTW I ran a Yank 3600 with the cc503 and it was a stout combo, daily drove it and hauled *** at the strip.
I vouch for the brake vacuum part. I am running stock stall, and cannot use the full potential of my Hawk ceramic pads, and thats really pissing me off. A stall is coming soon, I'm trying to break the transmission everyday I drive it to give myself an excuse to drop it out for a rebuild.
Don't rush your build buddy, if you don't have the cash for something thats a bit better, just be patient and wait. Its better than spending the money twice.
I was also working with a very tight budget, but I waited a couple of months, did more research and listened to what more experienced people had to say first, and then made my decisions. By then I had saved up money to buy the right parts for he build.
Good luck with your build bro
Old Nov 29, 2009 | 09:56 PM
WARDOG's Avatar
Default advice
Thanks for the advice you 2 and this is more of a daily driver with a kick than a track car . Like i said later on when uncle Sam gets me my money and the wifey, im gonna go to to Circle D for a 2800-3200 stall . For now im gonna go with a Dacco performance 2500 stall for 200 shipped. Tomorrow i gotta send my PCM to get reprogrammed and have some questions for you guys that done it..
1. With the cc 503 what should i set my rev limiter to safely? Is 6200 too much?
Ill ask more questions as i go , any help and good imputs are always appreciated ....
Old Nov 29, 2009 | 11:37 PM
ADM's Avatar
ADM
My car shifts at exactly 6375 (according to my data logging), stock bottom end, pro magnum rockers and comp cams 918 springs. Not sure what my red line has been set to.
Old Dec 2, 2009 | 06:39 PM
WARDOG's Avatar
Default goodies
Well im gettin a pcm sent form PCMFORLESS.com tuned to my car and it should be here tomorrow or friday. While i wait for it i stil have to assemble the rest of the engine and tranny. I got some goodies today, Dacco Performance Plus HD7730 2500 stall, 8.5 jegs wires, accel coil, lt4 knock module, percys seal 4 good gaskets, new water pump, new opti harness and urethane motor mounts. Im still waiting for my egr block off plates, while i wait im wrapping the headers with header wrap then a good coat of 2000 degree paint.
7730
Brand: GM
Model: 700-R4 30 SPLINE
Stall: 2300-2500
Family: PRO-STREET
Bolt Pattern: 700-R4
Engine: ALL
Brazed Impeller: YES
Brazed Turbine: YES
Bearings: 1
Washers: 2
Balloon Plates: Optional
Notes: Unit contains a lock-up clutch.
Old Dec 2, 2009 | 06:49 PM
WARDOG's Avatar
Default torque specs
I would like to know if anybody got a link to were i can find the torqe specs for all the bolts on the engine , accesories, and tranny etc. Any help would be appreciated thanks
Old Dec 2, 2009 | 07:25 PM
  #32
Sk8phreak88's Avatar
shbox.com
Almost everything you need put together right there.
