From "cc 503 install help" to a full rebuild:)
http://www.competitionproducts.com/p...?number=652394
http://www.competitionproducts.com/p...p?number=98213
Plans changed all of the sudden and it al started with this block
With the Cloyed double roller, you are aware that you need an electric water pump, vented optispark, and some other minor modifications, correct?
emissions delete:
smog pump and plug stock header copiping connections for smog pump
do not delete the gas tank venting. If you do then install a small air filter on the end. I still ran the vent tube up towards the front of the engine and then placed the air filter on it.
egr delete.
You can go to shbox's website and look through his emissions sections. he has great documentation. I used his site exclusively to delete all mine. everything works great.
. The Best V8 Stories One Small Block at Time
I would NOT use them again or recommend them.
There are other factory gm parts site that are much better to deal with.
You can get the stock gm chain from summit too. Just put in the GM part number.
A tad higher than gmpartsdirect but by the time gmpd gets done raping you on shipping, summit is cheaper.
Stock rebuild is pretty cheap if you have a good machine shop that doesn't gouge you on pricing.
I've dealt with them several times, never had an issue.
http://www.bulkpart.com/Merchant2/me...e=4L60-700R4tc
