How to delete TCS?
Old Nov 10, 2009 | 11:25 AM
96blackta's Avatar
Default How to delete TCS?
Going to spend all day tomorrow doing miscellaneous things in the engine bay. What do I need in order to remove the TCS? My buddy says that it looks like we'll need a longer throttle cable.
Old Nov 10, 2009 | 11:35 AM
dilatedpeoples28's Avatar
yea you just have to get the non-tcs throttle cable. I couldnt find it new anywhere so I got one used. Just unbolt the tcs over the valve cover, disconnect the old throttle cable and run the new one. You wont have cruise control anymore so I just took that cable and tucked it up near the firewall.
Old Nov 10, 2009 | 01:24 PM
SPEED#1's Avatar
just disconnect the tcs cable and unplug the module then get a non tcs throttle cable, new they are like $25 from gm
Old Nov 10, 2009 | 01:34 PM
Badazz 97 TA's Avatar
^yup. and if you want to keep cruise control obviously you will have to get a cable from a non TCS car also.
Old Nov 10, 2009 | 02:11 PM
Ponch95's Avatar
Yep I did this and it really is that easy plus that Traction Control box weights about 20lbs so get it out of the car Yes the new throttle cable cost $24 but your GM dealership probably will have to order it as for the Cruise Control GM no longer makes it so you will have to search around for a used one.
