URGENT - No brakes after CC503
Glad to see I am not the only one that saw this. Do five brake jobs a day and you start seeing lots of dead ABS units from guys in the shop forcing nasty fluid back up.
I always open the bleeders when trying to compress the pistons, always keep an extra bottle of fluid to top up the reservoir.
probably its air in the system. are u sure u followed the right order of bleeding the brakes, u have to start from the furthest caliper from the master cylinder,,,
First - rear RH
second - rear LH
third - front RH
last - front LH
i followed this order when i bleed my system. BTW i bleed my brakes with the engine off never did the ABS unit, and they work just fine
First - rear RH
second - rear LH
third - front RH
last - front LH
I tried the drive and pump method earlier, made no difference. Guess will just have to bleed them again one at a time.
Adel, I think I saw your car at Master Exhaust, changed to cutouts at the headers and Y pipe now?
If you are selling your duals set up, let me know
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If you bleed some more and the sponginess is still there, it could be a bad master. It seems like the air is in the fronts as the pedal is soft to the end and I believe the last bit is the rear brakes...where it seems to get tighter. Anyway, if you don't see fluid anywhere, and it is not going into the booster, it could be bad internals in the master as well allowing fluid to push past and you lose pedal. Try bleeding first, but the master may have just taken a dump coincidentally with the cam swap.
Why would you bleed the brakes to change pads or rotors? I do the same a SS RRR just open the res and c-clamp the pistons down. Ive never had any type of issues, and just like he said it take about 2 stops for the pedal to come back.
My buddy once did his rotors at my house on his 99 Firebird and tried to bleed them wich left his car just like yours. No pedal and crappy brakes.
90% sure you still have air in the lines.
While I attempted to bleed the brakes, I had someone constantly top it up to the correct level.
I guess it needs a full severe bleeding.
Yeah mine is doing this after my hotcam swap. I think I have a huge air bubble somewhere in the lines. My car is doing the same symptom. I just hope my master cylinder has not taken a dump in the last 9 months it has been sitting.
#32
i just fixed the problem you are having by fixing my lifter preload. preload was wayy to tight. (thanks to the comp cams tech line advise
) throw a vac guage on it. mime was was flucuating between 13-15 in hg. i re adjusted the preload today and i got a great pedal again!!! before i had brakes just had to push the pedal twice as far. now its as good as new. and i might add that it runs on top end much better too. so my vote is you look there.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#33
Took it to a local service center at a gas station, as they had a vacuum bottle for bleeding. And they had a lift so I managed to inspect under my car and search for any leaks I have from my build, thankfully none.
So, away we bleed, and you wouldn't believe the amount of air that was in the lines! We flushed the whole system and now I have excellent brakes and fresh fluid.
I must say, the new rotors with the Hawk Ceramic pads are incredible! So much improvement over the stock pads. I should have gone Hawk a long time ago![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks to all who chipped in from their experience and knowledge and helped out
