Dual fuel and injectors
Do you run both pumps all the time, or only under power.
If you do run both pumps all the time, how do you prevent backlowing through the dormant pump?
Any pics / write up would be great.
On injectors, what is recommended for something in the 40-49lb range.
Has anyone used SVO Green tops? They're rated at 42lbs and I think run a little higher w the fuel pressure of an LT1.
http://cgi.ebay.com/ebaymotors/42-In...Q5fAccessories
I answered one of my other questions through searching. Nothing special needed when running 2 pumps, but only 1 when not under power (spraying, high boost, etc). The walbro pumps are designed not to backflow when pressure is applied in reverse, if that makes any sense.
No checkvalve of any sort needed.
So now I just need to get both of them in the tank.
anyone have pics / writeup for an lt1? There's a write up in the fuel section but it's on a 98 ls1 that doesn't have the plastic bucket
i got mine from buyfordracing.com (new, duh) for a lot less than that ebay ad although the price has gone up a bit since.
I thought about the green tops but they look retarded, I'd have to paint them
Dual intank pumps for LT1
I'll have to talk to n20 outlet about it. The kit says "upgradeable to flow 400hp".
Not that I'm gonna shoot that much.
I think you have to upgrade the fuel line to even go over 175
