Found my problem...
thanks man i am too lol if i dropped a valve through my piston i woulda just parted the car then killed myself.
I got a set of the proven defective Comp 918 beehives a few years ago. Busted the top coil on three in just 20 miles. Called Comp and they were helpful and more than made the situation good.
I then went with the Patriot extremes and have been pleased with them and have not encountered any valve float or other issues. When I had the PAC beehives, I had massive float at 6K RPM and the motor fell on its face.
I know some have had success with the beehives but I still believe they simply work better on the lighter LS1 valves than our heavier LT1 valves.
I will never run a beehive again.
i just ordered a set of the patriot extremes' hopefully theyll be as good as everyone says they are
You will love the Patriots but just one word of warning. I installed some extremes on a friends LT1 and the valve seals they sent were the wrong size on the OD and the inner spring made contact and actually pulled the seal off of the guide. Clearly this ain't no good.
I called Patriot and they said a wrong batch of seals made it out for the LT1 extreme kits. Obviously you have to have a tight OD to ensure they don't make contact with the inner spring. Once they sent the right seals, all was good. IIRC, the clearance on each side of the seal was about .010" from hitting the springs. Now thats close.
Just make sure you dont have the same problem.
At the time my heads were off of the car for some work so I had my engine builder machine my guides down to .500" just like LS1 heads. This allows me to use any spring combo practically under the sun and there is plenty of room for the seal without having to go thin wall thickness.
Some good advice for anyone doing LT1 head work. Have the guides machined down to .500". It was rather cheap to do.
Ive been running the patriot gold extreme's for a while now also. Car gets its *** kicked regularly, and often see's 6700 to 6850, and have had no issues. (except the stock opti crapping out) I'd love to hear the things this guy heard 'around his car club'. I'm sure Lloyd wouldnt use them as his upgrade springs if they had a flawed history. I think mad hatter is just running his mouth to hear his voice.
Get a ******* life man. I clearly recall two members on AZFBA dropping valves with Patriots and toasting their engines. They were LS1s, but Patriots still. God forbid I post something helpful.
They are a great spring and the price you can't touch with anything else. I run them in my car and hundreds, maybe thousands of LSx cars with not 1 single issue.
Those springs were 26918s and I found the site, and that caution, using Google.
Just thought I'd pass this along.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Having a hard time believing they're junk based on what you "say" when I look at Larrys post that "PROVES" otherwise. If anyone would be able to recognize a trend -good or bad- with an aftermarket part it would be spped inc. Thousands of cars running the patriots with zero issues is simply too much to dismiss.
I know you paid a lot more for your PACs and I'm not saying theyre a bad spring, or even that the Patriots are better. The 1518's are a badass spring for being able to do what they do in a single spring but that does not automatically make the Patriots "junk". I just dont see how you can say that, but whatever. I'll keep running and enjoying my "junk" $270 springs.
.02
I ran PAC 1218's. They floated but never broke for nearly a year.
I did not run 1518's but if I recall, its the same spring but its nitrited (spell check) so I will assume they would perform the same but obviously hold pressure longer. Two sets of 1218's were installed at 1.750" IIRC exactly as Lloyd and Brett suggested. Still floated.
Installed PSI (Nascar quality springs IIRC) LS1 beehives which were a bit stronger than the PAC's. They floated too.
Installed Manley (forgot the p/n) beehives and the float was gone but 5 were busted in two weeks. Manley claimed to have a bad batch similar to Comp.
Installed the Patriot Extremes, zero float and have been running strong for nearly two years.
Personally have seen loads of posts on many boards about busted beehives regardless of brand. I dont recall a single post on busted Patriots. Not saying there are not any, but I have not seen any. Maybe someone can produce them?
They may be Chinese junk, but the gov'ment is taking all my damn money.
My intent was just to pass along the latest news on a Beehive failure, not to start a "my spring selection is better than your spring selection" type of exchange. I did it just for informational purposes and I tried to make that clear. I think reading comprehension, personal bias and the knee-jerk need to defend one's purchase of Beehives played a part.
Some assumed they were from original batch offering, but I reminded them that, at first, it was thought to be only a bad batch or two, but as it turned out there were many batches involved in failures. IIRC, one Forum member (forgot which Forum since I visit so many) was compiling a list all the batch numbers involved and it seemed to be getting lengthy. Suopposedly, the problem(s) have been corrected now.
I'm wondering from what batch the OP's springs came from - original or newer. Are they from the batch of supposedly corrected springs? Knowing that would be important to others considering buying them.
Maybe it was a bad batch of wire from which several spring batches were made, I don't know, but however it came about, it certainly speaks to the failure of quality control in their manufacture.
Also, I don't if Comp winds their springs from material bought from a separate supplier or whether they buy them already wound. Anybody know?
Personally, I'm not a fan for single springs in performance applications, but for those who like them I say: to each his own, mine's just a personal preference thing. I do recall that in the most recent LT1 cylinder head shoot-out done by GM High Tech Performance mag, all the heads, except Edelbrock's, were tested with dual springs. IIRC, no mention was made of the brand, etc., of specific springs being run though. In spite of that, there's no proof of how well any of the those springs would hold up over repeated high RPM use.
The springs on the new Dart Pro 1s I bought for my son's 96 Vette came with doubles with a damper and I'm running Crane duals on my 96 Vette.
I do know that LE highly recommends Golds and from what I've read, PACs seem to have a good rep. As with all springs, they must be set up correctly and total valve train weight is definitely something to be factored in, especially if the springs are being called on for regular high RPM use. So let's all agree to keep the revs under 3 grand and all of our springs will live forever.
When I use to build 8 second quarter mile BB engines, springs were considered an expendable item, even with the triples we ran.
As with most things, I don't believe there's ever going to be universal agreement on this issue but I believe the exchange of information and views is helpful. The more feed-back we have the better, more informed choices we can make.
Just my thoughts.
Jake
