Found my problem...
Old Dec 2, 2009 | 10:10 AM
  #41
JAKEJR's Avatar
To guys who have had problems with their springs, I'd like to know the specific procedure used to set them up. What instructions are being given you on how to do it and who made the recommendation.
Maybe there's a clue in that.
Care to share?
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 2, 2009 | 10:23 AM
  #42
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by wrd1972
Again I ran the 918's, three busted in 20 miles.
I ran PAC 1218's. They floated but never broke for nearly a year.
I did not run 1518's but if I recall, its the same spring but its nitrited (spell check) so I will assume they would perform the same but obviously hold pressure longer. Two sets of 1218's were installed at 1.750" IIRC exactly as Lloyd and Brett suggested. Still floated.
Installed PSI (Nascar quality springs IIRC) LS1 beehives which were a bit stronger than the PAC's. They floated too.
Installed Manley (forgot the p/n) beehives and the float was gone but 5 were busted in two weeks. Manley claimed to have a bad batch similar to Comp.
Installed the Patriot Extremes, zero float and have been running strong for nearly two years.
Personally have seen loads of posts on many boards about busted beehives regardless of brand. I dont recall a single post on busted Patriots. Not saying there are not any, but I have not seen any. Maybe someone can produce them?
They may be Chinese junk, but the gov'ment is taking all my damn money.
I'm with you and Speed inc on the Patriots. We have literally thousands of sets out there and we do not run into issues with them. I would run them without hesitation. We offer both the Patriot and the PAC and very competitive prices BTW We also really like the Manley dual springs, I'm about to start up my engine with a VERY aggressive cam on a set of their singles to see how well they perform as well.
That said, if you went through 5 different sets and 4 different brands of single springs and had problems, at some point it must be noted that you were probably not running springs that were the right specs or possibly were not set up properly for your application
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 2, 2009 | 03:27 PM
  #43
wrd1972's Avatar
It is very hard for me to argue with this logic.
At that time I had a more agressive cam making around .610" lift on XE lobes. I think that might have contributed to the float and the breakage. But the fact still stands, Comp and Manley both admitted to having defective stock at around the same time. I am confident there was no issue with the install height.
I have since replaced the cam with one in the .570" lift range and have not busted any springs since. But to be fair, the only springs I have since were the Patriot extremes.
Old Dec 2, 2009 | 04:23 PM
  #44
At that time, all of those springs were rated at .600 lift at 1.800" installed height. Not only were you running .610", but you lowered the installed height .050 on top of that. You were .060 past the spec of the spring. They coil bind at 1.140 and with your installed height you have exactly .610" to coil bind. The Patriots coil bind spec is 1.090. The Patriots gave you the pressures you needed and still have the additional room to handle your lift at that installed height. It just all around wasn't an application that warranted those singles. It wasn't just a little out of spec for them, it was significantly beyond their limits. You should never have max lift closer to coil bind than .050"
I'm not lecturing BTW, I'm just trying to provide some insight from what I would look over when evaluating and/or laying out specs for any build I would put together or check out for a customer.
__________________
Old Dec 2, 2009 | 05:37 PM
  #45
AChotrod's Avatar
My Patriots are great so far!
Old Dec 2, 2009 | 05:44 PM
  #46
SoxXpupPeT's Avatar
This truely is turning into a good post about a broken spring lol. alot of insight has been put out here and im sure others will appreciate it the way i do. after a long wait my springs came in. i was very excited to see the nice white box that housed the products needed to bring my car back to life. unfortunately for me the spring compressor i have doesnt quite fit around both springs to hold them both while trying to compress it so now im going to try to modify the arms or find another spring compressor. today i atleast got the old spring out (which came out by me flicking the locks out with my finger) and installed the new valve seal.
carnage
new stuff
i really dont wanna take my heads off but if i have to i will. and perhaps send them out for alittle diet
Old Dec 2, 2009 | 05:47 PM
  #47
AChotrod's Avatar
Nice! If its getting cold just send the heads off now!!
Old Dec 2, 2009 | 06:10 PM
  #48
SoxXpupPeT's Avatar
i would love to but i dont need too. i just need to get a better compressor or just modify the one that i have. i have alot more to worry about before i add more power
Old Dec 2, 2009 | 06:13 PM
  #49
Z-RATED94's Avatar
Same here!! I was a little leary about the quality with them coming with titanium retainers for well under $300. The 918s I had before that only lasted 1500 miles before they were worn out, so I figured what the hell, lets give them a try.
Old Dec 2, 2009 | 07:58 PM
  #50
wrd1972's Avatar
I have the Crane valve spring that slips over the rocker studs, then you tighten down a single nut in the middle and both springs compress easily and with no effort at all. This is the best valve spring compressor I have used when changing springs with heads on the motor. The screw type does not easily work with dual springs.
Try to find the Crane compressor. I can change my springs out alone in 2 hours with it. Its worth gold.
Old Dec 2, 2009 | 09:00 PM
  #51
gregrob's Avatar
Tims tool works just as good, just does one spring at a time though.
Old Dec 2, 2009 | 09:17 PM
  #52
AChotrod's Avatar
Not for the springs!! For the porting !
Old Dec 2, 2009 | 11:54 PM
  #53
SoxXpupPeT's Avatar
i work at a machine shop so ill be attempting to make my own tool to compress the springs. i had made one along time ago but it wasnt nearly as thick of a material as i needed it to be. if not then i might just pay up the money and get the speed incs version of the crane tool. or i might just try to make one of those too :p
does anyone know how to get all the cylinders at TDC other then the "air through the spark plug" method ? somoene had said how to do it but it was for an ls1 which i know is alittle different
Put #1 at TDC, do cyl 1 and 6. Rotate 90*, do 8 and 5, rotate 90*, 7 and 4, rotate one more 90*, do 2 and 3. Done.
thats wha they said for the ls1. does anyone know it for the lt1 ? thanks
Old Dec 3, 2009 | 08:45 AM
  #54
wrd1972's Avatar
http://shbox.com/ci/valve_spring_swap.html
As long as the piston is anywhere near TDC, your fine. The only way to really completely drop a valve is if the piston is at BDC and I am not even then convinced that it would fall loosely into the cylinder.
If the top of the valve drops into the guide, after you have recovered from the heart attack it causes, just pull it out with a magnetic retriever.
No need to pump the cylinders up with air unless you just have supper easy access to the plugs which of course will never happen in LT1 world.
Old Dec 3, 2009 | 08:57 AM
  #55
We sell the Crane tool that is now made by another manufacturer since Crane shut down. It is widely considered to be the best. It's 121.95 and we have trouble keeping it in stock because it is so popular. I have one left right now
__________________
Old Dec 3, 2009 | 10:23 AM
  #56
wrd1972's Avatar
Good to hear you guys have it. I thought it had died off. This thing is worth every bit of $121 bucks and every LT1 gear head should have one.
Old Dec 3, 2009 | 11:23 AM
  #57
I just found out the LT1 version is now dead, we will only be carrying the LS1 version from here on out.
__________________
Old Dec 3, 2009 | 11:45 AM
  #58
wrd1972's Avatar
Temp
Just kidding.
Okay, some capitalist pig can make some bucks here by making a copy of the old Crane SBC dual spring compressor.
Old Dec 3, 2009 | 11:49 AM
  #59
SoxXpupPeT's Avatar
thanks wrd1972 that comes in handy. i have mac mids and its not to bad to get the hose in there. i just wont have a compressor around when i do my springs. and thank you scoggin. that sucks that you dont have it anymore but thats the way the world is. i found that byunspeed has a crane look a like for around $100 but i dont have the time for that. im going to make one after work today and see how it works out. wish me luck
Old Dec 3, 2009 | 12:54 PM
  #60
1redta's Avatar
I used the Tims's valve spring tool. It worked GREAT!! and was cheap As far has pressurizing the cylindres I bought the adapter and hose. I tried to hook up no. 2 cylinder and it was a pain. I removed the rocker and pushrod and the compressed the spring the valve slid to the top of the valve guide. I then used my 1/2 rachet and rotated the engine till the valve cam back up on that cylinder. I had no problems except for making sure I measured the installed height a couple of times before I put the spring back on Don't forget the valve seal when puting the spring on that is a PAIN
