heating question?
Old Nov 26, 2009 | 05:53 PM
BallerCamaro21's Avatar
Default heating question?
ok i have a 97 trans am and when i drive my car anytime the temp only goes a quarter way up and i have no heat. no mater how long i drive for. but sometimes it does go have way up for only 10 second but then goes back down and still not so goo of heat. The water pump is not old and the heater core has been replace and then thero stat has been replace. What could be the reason why i dont have heat? any help here please
Old Nov 26, 2009 | 06:45 PM
red-_-z28's Avatar
Theres no problem with that..
Mine does the same
If you were overheating then id be worried!
Like for me when im driving its on the 2nd line, if i were to go in a drive thru or sit for awhile then it would cliimb to the 3rd
Old Nov 26, 2009 | 06:53 PM
airfix's Avatar
What degree thermostat do you have in your car?
Old Nov 26, 2009 | 07:01 PM
camaroz28383's Avatar
well generally the prob with no heat is clogged heater core but yours is new how old is it?
next cause is that little restricter on your heater core line. You cant just pop it off and check it though because its crimped on you can try and back flush the heater core to get any crap out of the lines and any thing that might have made it into the new core. other then that there is really no reason you have no heat unless you have like a 160 stat
Old Nov 27, 2009 | 04:02 PM
i think it has a 160 stat in it. And the heater core is like 5 or 6 months old and where is this resister at?
Old Nov 27, 2009 | 08:38 PM
fleetmgr's Avatar
Get rid of the 160 stat and you should heat just fine.
Old Nov 28, 2009 | 03:52 PM
the restricter is on the heater line about a foot from the water pump just follow the line from the water pump and its a black plastic thing on the line
but I'll say its the 160 stat thats giving you problems try swapping it out for a 180 should make a world of difference
Old Nov 29, 2009 | 11:43 AM
i look for the resister and i couldnt find it at all....
Old Nov 29, 2009 | 03:13 PM
Its between two crimped fittings but i wouldnt worry about that right now as having a 160 stat will allow for basically no heat when mines at 160 I get barely a warm breeze If you want to see if you get heat once it warms up more you could pull your fan relays and let it heat up just make sure you pay attention to the gage
