Security light on. Now what?????
My question is what causes this? Is it the key? Is it the ignition? or could it be in the computer? Can I tune out or delete the vats in the computer so this doesnt happen again?
Thanks for the help guys and have a Happy Thanksgiving.
even if your key is not "loose" in the key tumbler, the contacts that touch the key or the wiring that passes the voltage, or the BCM/VATS module that interprets the voltages could be faulty. Hopefully when you make a few checks it will just be a loose wire or something. You cannot just tune out VATS to correct the problem. You'll still have to put in the correct resistor under your dash to make the system think the correct key is there all the time. And then, thats only good if your module(s) aren't on the fritz.
So it must be the key than right? It doesnt look bad and it fits in the ignition good but thats all I can think of?
How much is it to get a key from the dealer? Do I need to take the whole car to them or just the key?
