hot cam install questionif i
Old Dec 4, 2009 | 06:26 PM
shutzero's Avatar
Default hot cam install questionif i
If I'm going to be putting the hot cam in my car what are some of the other things I need to get to make it run lol
Old Dec 4, 2009 | 07:11 PM
1 Craz28's Avatar
Timing cover gaskets, intake manifold gaskets, valve springs and seals for a start. I went with procomp lifters and 1.6 roller tip rockers for affordability. And Lunati has an affordable timing set too.
Old Dec 4, 2009 | 07:12 PM
1 Craz28's Avatar
You might as well get a set of GM guides plates and do a NSA rocker set-up!
Old Dec 4, 2009 | 07:16 PM
riceburnerZ28's Avatar
Everything you need to know is right here.
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Old Dec 4, 2009 | 07:17 PM
malott's formula's Avatar
hottcam isnt that big id put the gm847 cam it bad ***, o ya if u dont have a stall its not gona take very hard
Old Dec 4, 2009 | 07:22 PM
shutzero's Avatar
If I don't have a stall for the hot cam or 847?
Old Dec 4, 2009 | 07:42 PM
dlk1950's Avatar
I would do a stall first,probably get you in the 12s.
Old Dec 4, 2009 | 07:55 PM
shutzero's Avatar
I plan on stallin it after the cam, I don't wanna go too high on a stall or cam because I still want it to be somewhat streetable lol
Old Dec 4, 2009 | 07:59 PM
dlk1950's Avatar
Just dont go too low on stall, my 3600 is very streetable.
Old Dec 4, 2009 | 08:13 PM
shutzero's Avatar
I was going to go with a 2800
Old Dec 4, 2009 | 08:26 PM
Badazz 97 TA's Avatar
omg you are so awesome and smart!
your an idiot btw.
2800 should be good. i wish i would of went with a 3200 now. oh well, the 2800 is still good. Thats what i have. very sreetable and fun to drive.
Old Dec 23, 2009 | 11:32 AM
shutzero's Avatar
cool thanks guys, so ill get the 1.6 nsa roller rockers, guide plates, timing cover gasket, intake manifold gaskets, valve seals....do i need pushrods? and will the ls7 ilfters be a direct fit?
Old Dec 24, 2009 | 08:06 PM
Black96Z's Avatar
I wouldnt go smaller than a 3200. I love my stall but wish i would have went with a 3600.
Old Dec 24, 2009 | 09:05 PM
shutzero's Avatar
maybe ill go 3200 but i wanna make sure i get all the parts for the cam swap before i start tearing into it
Old Dec 25, 2009 | 03:37 AM
hitmanws6's Avatar
a 3200 stall is more than enough for a cam that small.
Old Dec 25, 2009 | 06:04 PM
JAKEJR's Avatar
Yes, you're going to need new hardened pushrods of the CORRECT length. So WAIT until the lifters are in and use an adjustable length pushrod checker tool to determine what length you need.
LS7 lifters have a different pushrod cup height so you'll need to measure, but they'll drop right in.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 25, 2009 | 06:27 PM
WhyHelloOfficer's Avatar
For simplicity's sake, Thunder Racing sells an "LT1 Cam Swap Gasket Set"
http://thunderracing.com/catalog/?ac...vid=4&pcid=157
It is basically everything you'll need for the cap swap.
I ran a PI 2800 Stall with my Hot Cam, definitely a good setup. Pretty well mannered, and you can't beat the package deal of all of the parts. In hind sight, I probably would have gone with an XFI Grind Comp Cam and built my own kit, slightly more streetable with more on the top end, but you definitely can't go wrong with the packaged simplicity of the Hot Cam Kit.
However, the Hot Cam is the best bang for the buck to run on the stock injectors and a tried and true setup. Don't let others tell you it is a crappy setup. It is reliable and solid. You won't be disappointed.
I ran a best of a 12.80 on street tires N/A and a 12.06 @ 117 on a 100 shot. You'll have a lot of fun with it.
Old Dec 25, 2009 | 09:19 PM
draggin97s10's Avatar
Wink
make sure to make a solid lifter when measuring for PR length..
