Help,my car hates me
Old Dec 6, 2009 | 12:01 PM
scott937's Avatar
Default Help,my car hates me
I have a 95 lt1 camaro with 69k on it. Ive had nothin but problems with the car since i baught it a year ago wit 65k on it and blew the motor a week later. Anyways long story short the cars a headache. I threw another code- code 16 and i guess that meant my opti-spark was on its way out. I replaced the opti&the car ran fine for maybe 25 mins or so. I drove it and turned it off then when i started it back up maybe 5 mins later the same problem came back and the car threw the same code. My question-what to do now? The TPS was recently replaced,fuel pump,water pump checked all wires everything im just sick of dumpin $ into it and the problem hasnt been fixed. Any and all help would be greatly appreciated....Thanks,Scott
Old Dec 6, 2009 | 12:22 PM
1 Craz28's Avatar
What is the description for a code 16? And who replaced the motor?
Old Dec 6, 2009 | 12:28 PM
Badazz 97 TA's Avatar
i would say maybe you forced the opti on too hard or you need to check the dowel pin length on the cam. If its too long it will put stress on the opti. I dont know, just kinda throwing some ideas out there.
Old Dec 6, 2009 | 12:33 PM
red-_-z28's Avatar
unplug your MAF and see how she runs..
Old Dec 6, 2009 | 02:56 PM
scott937's Avatar
The MAF is new too...i just looked at the wires closer and the one from the coil to the opti has a hairline tear in it. I electrical tapped it back up and took it for a ride and the same problem came up. Could this wire be the reason?
Old Dec 6, 2009 | 02:58 PM
scott937's Avatar
Code 16 is low res pulse circuit failure...me and my dad-the car was fine for a good 4 months after the new motor went in.
Old Dec 6, 2009 | 04:18 PM
Z-RATED94's Avatar
No idea if it's your problem or not, but you need to replace it if the insulation has a tear in it. Electrical tape is not going to solve the problem.
Old Dec 6, 2009 | 07:55 PM
SS RRR's Avatar
Village Troll
Why is that?
Old Dec 6, 2009 | 09:54 PM
joer6's Avatar
electrical tape does not replace missing insulation on the wire. you should properly fix the wire. what opti did you use for a replacement?
and it might be a good idea to test the opti harness.
Old Dec 7, 2009 | 12:27 AM
96blackta's Avatar
Your car does not hate you. LT1's put you through ridiculous tasks to earn their love... just like women.
Old Dec 7, 2009 | 02:59 AM
1994formulalt1's Avatar
all i can say is use an oem optispark get the harness while you are at it and the module also.
Old Dec 7, 2009 | 07:30 AM
scott937's Avatar
Haha yea this car is ridiculous...day 2 of owning it someone backed into it in a parking lot...day 5 motor blew...after the new motor was in 3 days later fuel pump went,its just one thing after another
Old Dec 7, 2009 | 06:34 PM
SS RRR's Avatar
Village Troll
Yes it does. Electrical tape works just fine if wrapped correctly. Another fix is to slit a strip of shrink wrap and put over the bare wire.
Old Dec 7, 2009 | 08:07 PM
AChotrod's Avatar
sig worthy right there!!!
Old Dec 8, 2009 | 01:37 AM
96blackta's Avatar
I can relate. I blew a head gasket a week after owning it. Then several months later destroyed my motor. After the rebuild the radiator sprung a leak. And I find new nicks and scratches all the time... STOP PARKING NEAR ME DAMMIT!
Old Dec 8, 2009 | 02:39 AM
marc97taws6's Avatar
That it was VVVVVVVVVVVVVVVVV
First time I took my car up to my university (Ames, Iowa): Several comments on how good it looks + a few fresh key marks. FML, right?
Old Dec 8, 2009 | 02:53 AM
BLK,97,T/A,M-6's Avatar
I agree!
Old Dec 8, 2009 | 02:54 AM
Ehh Marc beat me to it... Still funny as **** though
Old Dec 8, 2009 | 02:56 AM
Radiator probably sprung a leak cause of the blown head gasket...... I see that kinda **** all the time.
Old Dec 21, 2009 | 07:45 PM
kmracer's Avatar
you must be ******* joking.
