383 Head Choices...
Any recommendations, pros, cons, feedback etc would be appreciated. Thanks.
I too second the AI 200cc heads (ported stock castings). They have proven themselves time and time again. See sig for a similar setup.
if you're looking for 430-450rwhp a stock casting is gonna be pretty hard to get there but it has been done before, AI and LE both proven performers. don't even waste money on aftermarket castings imo unless you plan on dropping the extra coin to have them ported.
basically the point I'm trying to make is a cookie cutter build (off the shelf cam, basic head porting, mail order tune, etc. which is quite the common place on this forum) will be hard pressed to make that number, so a quality well thought-out one is the only chance IMO. to get that kind of power you'll want a head flowing close to 300cfm and the AI 200cc's last I checked were around mid-high 290's which should put you somewhere in that goal all parts complimenting
Through an auto I would start looking towards ported aftermarket castings. No matter what you hear 450rwhp through a stalled auto on ported stockers is far from common, and a bigger head will make it easier for you.
Maybe I'm just biased and spoiled to have a good builder nearby, but it's hard to settle for less once you know better
I'm glad you found a good LT1 builder since they are few and far between, and your car seems to run ok for what it is
. The recommendation(s) on bumping the CR are good ones. About 11.5 with a tight quench, his cam, and it will be good for pump gas.
There is more info on that subject that you can imagine.
I did... and I'm still torn on the subject.
