LTx gurus what is max hp u think block will handle?
Old Dec 9, 2009 | 08:11 PM
James Montigny's Avatar
Originally Posted by OutlawZ
I'm gonna call fereday tommorrow and try to get the skinny.
Old Dec 9, 2009 | 10:37 PM
BIG PURPLE's Avatar
the lt1 block with the proper machine work can hold 1285 hp to the wheels, but you must have all of your rod and main bearing clearances setup the right way.
Old Dec 9, 2009 | 10:42 PM
BizZzatch350's Avatar
Moderator
Rick never had a 102, believe it was a 91.5. It spun a bearing that Friday he went 8.0, right after that pass, went to turn the boost up and the car was hurt so it never ran again. He bought a SBC to go race some class in ORSCA but lost interest. Still has the chassis. But yea, the car never hurt the block, broke trans, lost a slick in the burn out box at HMP, the block was a trooper though.
Old Dec 9, 2009 | 11:07 PM
95 Formula's Avatar
i don't think the "limit" has been found yet.
Old Dec 9, 2009 | 11:28 PM
OutlawZ's Avatar
maybe i'm gonna look for it.... an FI94x might be just the way...
I think the 8.08 can be beat with the right car.....
Bigpurple did your car put down 1285 RWHP???? I know you're deep in the 8's at 167ish but I was thinking that was more around 1000-1100 at the wheels.
Old Dec 10, 2009 | 12:03 AM
BIG PURPLE's Avatar
its along story to explain but i was knocking right @ the door but i broke a rocker shaft on the dyno before i could reach the #. i went 8.50 @ 171 on 275drs. we were playing with the ams1000 tring to get my 60" back in the 1.2's but just couldnt get the box figured out. i feel we could have went some low teens or twentys.
Old Dec 10, 2009 | 02:39 PM
OutlawZ's Avatar
******* sick.... well good luck with the new build man. If I had the money I would have bought those turbo headers in a HEARTBEAT. Did you have a motor plate or were you on the motor mounts? I'm thinking about definitely doing a motor plate this time around...
Old Dec 10, 2009 | 03:14 PM
lt1badbird's Avatar
He can correct me if im wrong but iv'e seen pics of his engine bay and pics of the tubular K member he was selling off his car and i believe he was running motor mounts
Old Dec 10, 2009 | 03:28 PM
LittleRedZ's Avatar
big ricks thrust bearings were getting eaten up left and right he gave up on the lt1.
Old Dec 10, 2009 | 03:37 PM
Tony Shepherd's Avatar
Who built Rick's engines? LME?
Old Dec 10, 2009 | 04:28 PM
OutlawZ's Avatar
HPE built it IIRC......
Thrust bearing failures are 100% always something external to the motor... usually too much converter pressure pushing against the flexplate....
not a problem with the engine IMHO... I had a thrust bearing failure with my 355 and have since modified my TH400 so that pressure doesn't build up in the converter. John Kilgore did the work and I haven't had an issue since.
Old Dec 10, 2009 | 04:32 PM
  #32
BIG PURPLE's Avatar
thanks outlawz, no I didn't have a motor plate. Madman made some type of torque turn buckle to help stablize the motor. I'll try to post some pics later so I can give you guys an idea what the part look like.
Old Dec 10, 2009 | 04:54 PM
  #33
LittleRedZ's Avatar
huh, never had that problem i didnt have to modify anything and i'm pretty sure with a huge blower like YSI, coged at that motor saw about 1000 crank HP and bearings didnt even begun to wear off whe white coating they put on the from the factory after a half of season of running with YSI and about 2 months with 12ribed procharger. maybe i got lucky
Old Dec 10, 2009 | 04:56 PM
  #34
Moderator
HPE was building motors in house, you would be suprised at how simple the parts were in that motor far as the short block goes.
Old Dec 10, 2009 | 04:58 PM
  #35
LittleRedZ's Avatar
i dont think so either, i've never really seen a 2 bolt splayed block actually fail. Usually bearings fail, i guess we'll see when Sykora ever decides to put the beast to the test
Old Dec 10, 2009 | 05:03 PM
  #36
LittleRedZ's Avatar
totally off topic i see my name fallen down to #14 quickest damn that didnt take long congrats to everyone, unfortenatly i can no longer keep up and i give up so if anyone needs some nice parts check me out in for sale section. OH maybe we can do 1/8 trap speed fastest lt1 ? that should put me back in the top 10 with my 118mph trap
Old Dec 10, 2009 | 05:31 PM
  #37
OutlawZ's Avatar
I thought we were talking about Rick's.... thrust bearing failures usually happen from the back forward from what i understand...
Yeah I saw the parts list on the GMHTP article... I have just as good if not better parts in my shortlbock. The few things I saw that were cool is the belt drive, he 4 bolted the front main cap which nobody does, and the no longer available 215RR heads. My heads won't flow what those did (I think they were 33x cfm and mine are like 315-ish).... But on a boosted app you can make up for lost headflow with BOOOOOOOSSSSTTTTT...
My decision was based on the fact that this economy sucks. If I sold my motor it would only sell if I offered it up for like 6-7K.... I've got like 15 in it..... I mainly don't want to invest money building a grenade with the pin pulled but since everyone i've talked to hasn't found a limit to an LT1 block then realistically we're working with a 23 degree headed SBC with reverse cooling... no need for a dart block if i can make 1400-1500hp with this block...
With the motor just needing low comp pistons and a turbo cam i'm already like 60-70% there with the project... Just need the turbo, all the piping, intercooler, BOV, wastegate, and hot side to include the headers.... I'd rather start from here than start with 6 grand and nothing but space under my hood.... (6K doesn't go far if i'm trying to build a stout turbo motor).... even more foolish since with a piston and cam swap i already have a stout motor ready for boost...
I'm not going to do it until I get the car in the 8.80's on spray tho.... probably mid 2010 i'll rip the car apart...
Old Dec 10, 2009 | 05:42 PM
  #38
AChotrod's Avatar
I like this plan^^
Old Dec 10, 2009 | 05:54 PM
  #39
OutlawZ's Avatar
actually i'll rip the car apart after the 2010 shootout.......
I gotta rip Shepherd's car apart first at the track.....
Old Dec 10, 2009 | 06:05 PM
  #40
TAEnvy's Avatar
Oh thatd be something id love to watch.
Speakin of fast red nitrous cars though, what every happened to speed density's car, last I heard it went down, and then he bought a C5.
Did I miss an update, is it still down, is he still looking for 8s?
Ive been waiting for an update on that bad boy.
