Ok, really, how much power would I pick up with TD's?
I currently running LPP lontubes, ORY, and a GMMG catback. I have toyed with the idea of selling the GMMG and ORY and getting the LPP true duals that just came out. Before I make a decision, I just want to know, realistically, how much power would I pick up with TD's?
The only pro I can see is picking up some ponies.
The cons are I would lose a little ground clearance, my DS loop would no longer work and I would have to figure something else out on that, and I don't know if they would drone at all at highway speeds.
For anyone who has true duals, do they drone at all while driving around? These will be dumped at the axle.
The REAL problem with a F body catback is the crossflow muffler. Take that off, put a straight single in out muffler on with a single outlet on the drivers side and you would be amazed the power even a stock catback can support.
I would venture to say a LSx catback with a muffler like above would support 450rwhp.
A buddy has a 2001 SS with heads,cam etc with a SLP center mount exhaust (CME) with a 2 1/4! y pipe It gained nothing uncapped. Makes 450rwhp.
I don't think you'd see much gains going from GMMG to TD's...
GMMG isn't as loud and doesn't drone as bad as TD's and you have essentially the exact same performance. GMMG is probably THE catback for LS1's.
Im thinking about switching back to a cat back, with cut outs untill I start to spray the car.
A. I really love the sound a H/C package makes with a cut out at idle.(Awesome crisp crackle)
B. Im sure you loose low end HP/TQ with 3" TDs unless your car is a monster 450-500hp
C. I cant get any DSL to fit
D. TDs drone alot
E. TDs are loud as hell and cops dont like that.
F. I see lots of cars that dont make any gains by switching from a good CB w/cutouts
G. My car has dynoed less ever since I switched to TDs(with that said I also made a bunch of other changes so I cant really say it was the TDs)
H. Ground clearance
I. With a CB and cut out you can be loud or quite at the flick of a switch
J. Its illegal
Now dont get me wrong!!! I love my TDs and they look and sound bad ***, and for a track only car its great but its annoying on the street. For that reason Ill prob switch back sooner or later.
D. TDs drone alot
H. Ground clearance
J. Its illegal
D. TDs drone alot
H. Ground clearance
J. Its illegal
D. TDs drone alot
H. Ground clearance
J. Its illegal
