If this site is correct...
Old Dec 12, 2009 | 12:15 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Based on the thumbs up, I'm guessing the original poster is happy that he has 3.23's.
Old Dec 12, 2009 | 12:23 PM
SS RRR's Avatar
Village Troll
Originally Posted by ScrapSilicon
I believe the op mentioned somewhere else in another thread about going with a 3.73 set and if the diff has a 2.73 set the switch would involve more $ ..but who is to say after X amount of years the diff hasn't been swapped from the GU5 setup to a GU2 ...
Easy. Jack the back end up with jackstands. Mark the DS and a wheel. Turn wheel one revolution and count how many revolutions the DS spins and that will give you your final ratio.
Exampe: 3.23's= the DS spinning 3.23 times per 1 revolution of the axle/wheel.
Old Dec 12, 2009 | 04:57 PM
AChotrod's Avatar
My car does not register on that site . SLP had the numbers for me though. My car is the 555th WS6 made !!!
Old Dec 12, 2009 | 05:04 PM
gjohnsonws6's Avatar
Cool site
Old Dec 13, 2009 | 07:01 PM
djjab57's Avatar
Originally Posted by chevyman9306
why would it upset the op that he has 3.23 gears??? were the 2.73 gears stronger???
i bought 3:73's for a 2 carrier
Old Dec 13, 2009 | 07:23 PM
BTC's Avatar
BTC
I have trouble believing the number of cars that are 1 of 1.
Old Dec 13, 2009 | 09:36 PM
shbox's Avatar
LOL, goes back to the original topic posted...
"If this site is correct..."
I guess one answer is "they made a boat load of 1-off cars".
Old Dec 13, 2009 | 10:35 PM
LT1_Fireman's Avatar
Vehicle: CAMARO 2 DR
Year: 1994
Build Date: 1994-02-08
Found 117,270 vehicles matching your year and model in our database.
RPO Description Matches Compare
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
117,270
UU8 RADIO,AM/FM STEREO,CASSETTE,ETR,DELCO/BOSE,DOLBY,INCLUDES CLOCK CASSETTE STEREO(UU8)
33,677
U73 ANTENNA,FIXED FIXED ANT(U73)
115,914
U82 SPEAKER SYSTEM 3, DUAL DR MTD, RR PKG SHELF 3 SPKR SYS/BOSE(U82)
63,581
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
115,549
YK6 Unk. 674
1AA Unk. 2,523
1SA PACKAGE-OPTION 01 (1SA)
8,077
12B TRIM COMBINATION CLOTH, GRAPHITE (B) (92) CLOTH TRIM(12B)
52,769
12I INTERIOR TRIM GRAPHITE (12I)
53,465
17P WHEEL COLOR-SILVER (17P)
100,659
6HD COMPONENT FRT LH COMPUTER SEL SUSP (6HD) SUSP(6HD)
34,661
7HD COMPONENT FRT RH COMPUTER SEL SUSP (7HD) SUSP(7HD)
34,661
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
34,807
81U EXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
21,826
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
27,948
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)
66,680
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
117,270
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST(AR9)(EXPORT)
SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
117,270
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
90,058
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
88,044
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
110,270
B4C PACKAGE SPECIAL SERVICE POLICE PKG(B4C)
674
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
87,936
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
115,936
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
86,688
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
108,932
EGW Unk. 674
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
38,764
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
101,391
FLT Unk. 819
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
8,885
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
39,931
IPB TRIM,INTERIOR DESIGN (IPB)
116,162
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
39,931
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
27,600
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
31,873
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
110,226
LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
38,764
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
8,885
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
8,885
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
105,293
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER SIMULATED LEATHER STRG WHL(NK3)
30,864
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
102,102
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
34,884
R7A Unk. 107,831
R8S Unk. 11,767
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
117,270
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
110,237
Rarity...
There are 2 1994 CAMARO 2 DR vehicles (0.002%) matching your exact options list. There are 2 (0.002%) with at least as many options.
AND
Vehicle: FIREBIRD 2 DR
Year: 1995
Build Date: 1995-05-03
Found 49,204 vehicles matching your year and model in our database.
49,204
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
35,058
UT6 RADIO,AM/FM STEREO,CASSETTE,EQUALIZER,ETR,CLOCK STEREO CASSETTE/EQLZR(UT6)
19,497
UW2 SPEAKER SYSTEM -10, QUAD FRT DR MTD, DUAL RR SAIL PNL, AMPLIFIER 10 SPKR SYS(UW2)
35,058
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)
ANTENNA,POWER(CHROME) PWR ANT(U75)
35,058
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
40,027
47,438
WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
20,825
Y82 TRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
13,072
13,863
24,128
33,974
13Q MOLDING COLOR,SILVER METALLIC (13Q)
2,878
13U EXTERIOR COLOR,PRIMARY (13U)
2,959
6HB SPRING COMPTR SELECT FRT LH SUSP(6HB)
2,554
7HB SPRING COMPTR SELECT FRT RH SUSP(7HB)
2,554
18,393
18,393
AAA Unk. 44,587
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
5,635
49,204
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
38,582
42,101
41,652
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
47,924
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
47,965
43,601
48,953
40,492
44,586
20,825
45,444
9,167
21,750
34,329
J1F BRAKE,SPECIAL(EXPORT) SPECIAL BRK(J1F)
21,841
21,750
20,825
42,586
20,825
6,886
6,886
45,836
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
35,613
N60 WHEEL(ALUMINUM)(PAINTED) PAINTED AL WHL(N60)
20,640
QCB TIRE ALL P235/55R16 BW R/PE ST TL AL2 96T TIRE(QCB)
10,586
49,204
T43 SPOILER,REAR RR SPLR(T43)
10,470
12,846
Rarity...
There are 1 1995 FIREBIRD 2 DR vehicles (0.002%) matching your exact options list. There are 1 (0.002%) with at least as many options.
There are my two f-bodies.It was a bit suprising though the T/A is more rare than the B4C camaro...
Old Dec 14, 2009 | 08:57 AM
meissenation's Avatar
I don't believe that site at all. My car is a red 1994 with cloth interior and had a 3.4L v6 4L60e. It said my car was 1 of 1... yeah right. One of the most common colors interior and exterior with a common engine and trans. Don't believe it one bit.
Old Dec 14, 2009 | 09:22 AM
BTC's Avatar
BTC
On the bright side, the site appears to be good for pulling the list of options. I seriously doubt that my car is only 1 of 5, but I did order it as opposed to buying it off the lot. Still, it's not like there were thousands of options to select from. My car is a hardtop six-speed. I suppose those could be somewhat rare, but I have trouble believing there were only five produced that year with the options I selected.
I wonder what percentage of 94's were hardtops.
I still kind of regret not selecting the 1LE options group, but summers down south with no air conditioning would have probably sucked. Now, considering where I live and that I haven't driven my car in 9 years, it would probably be somewhat neat.
Old Dec 14, 2009 | 12:30 PM
96blackta's Avatar
No rarity info for my car...? Damn.
Old Dec 14, 2009 | 12:39 PM
  #32
BTC's Avatar
BTC
Maybe you got 1 of 0.
Old Dec 14, 2009 | 12:51 PM
  #33
djjab57's Avatar
If you parked your car next to one of the hundreds or thousands of similar cars in our database you probably couldn't tell them apart, but that doesn't mean they aren't different.
For example, some may have an RPO listing for the plant in which they were built. If yours was one of only a few that came out of that plant with a given list of options, it would come back as rare. Another car may have all the same options but was built at a different facility and thusly it's considered different.
To check any combination of RPO codes to find how rare your vehicle is based on the most important codes, click here or make changes to the selection above.
Old Dec 14, 2009 | 01:05 PM
  #34
SS RRR's Avatar
Village Troll
I know mine is legitimately rare for the color mostly. Teal was the most uncommon color offered for the 1996 SS. I have only ever seen one other Teal SS since I've had mine as well as what I stated earlier about SLP stating there were only 3 other SS's that had the same options/color as mine.
What does that say about its value? Not a diddly squat blessed thing.
Old Dec 14, 2009 | 01:08 PM
  #35
BTC's Avatar
BTC
I still believe the rarity statistics are not reliable. When I ordered my car, I don't recall being able to select every option individually. I believe they were grouped, and I don't recall there being that many choices. It also seems the manufacturing logistics required to produce so many "unique" automobiles would have been a nightmare.
Old Dec 14, 2009 | 01:29 PM
  #36
shbox's Avatar
The plant location has no bearing, since ALL 4th gens were built in the same plant in St. Therese, Canada.
There is just no way that so many random people could have 1 of 1 cars. Ain't gonna happen. Heck, go to a dealer lot and look at new cars. Dealers tend to order a bunch of cars for their stock with exactly the same options in variations of color.
Old Dec 14, 2009 | 02:46 PM
  #37
StealthFormula's Avatar
I hope you guys don't believe how rare they claim your cars are. There's a thread in the lounge where pretty much everyone got the same BS 1 out of 1 results. I'm sorry but the run of the mill red Z28's and black T/A's are not at all rare. If it's not an SS, Hawk, WS6, 1LE, B4C chances are it's pretty common unless it's an unusual color combo. Some cars are optioned very weird kinda like mine which makes mine extremely rare but doesn't make it worth any more, actually less since mine was a stripper from the factory and most want power options.
Old Dec 14, 2009 | 03:01 PM
  #38
djjab57's Avatar
Can anyone tell me what this option is
34,661
34,661
Old Dec 14, 2009 | 04:26 PM
  #39
shbox's Avatar
34,661
34,661
Those are the codes for the suspension springs. They come in matched sets (selected by computer).
