If this site is correct...
Old Dec 11, 2009 | 06:46 PM
djjab57's Avatar
Thumbs up If this site is correct...
then i have 3:23's and not 2:73's DAMN i guess i better buy some 3 series gears. Cool site though
http://www.compnine.com/vid.php
Vehicle: CAMARO 2 DR
Year: 1994
Build Date: 1993-10-13
Found 117,270 vehicles matching your year and model in our database.
RPO Description Matches Compare
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
117,270
U1T RADIO AM/FM STEREO, SEEK/SCAN, COMPACT DISC, HPS, CLOCK, ETR STEREO/BOSE(U1T)
29,904
U73 ANTENNA,FIXED FIXED ANT(U73)
115,914
U82 SPEAKER SYSTEM 3, DUAL DR MTD, RR PKG SHELF 3 SPKR SYS/BOSE(U82)
63,581
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
97,792
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
115,549
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
38,090
1AY Unk. 89,976
1SC PACKAGE-OPTION 03 (1SC)
86,469
12B TRIM COMBINATION CLOTH, GRAPHITE (B) (92) (12B)
52,769
12I INTERIOR TRIM GRAPHITE (12I)
53,465
17P WHEEL COLOR-SILVER (17P)
100,659
6HD COMPONENT FRT LH COMPUTER SEL SUSP (6HD) SUSP(6HD)
34,661
7HD COMPONENT FRT RH COMPUTER SEL SUSP (7HD) SUSP(7HD)
34,661
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
34,807
81Q MOLDING COLOR - BRIGHT RED (81Q)
16,919
81U EXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
21,826
9T. Unk. 25,813
AC3 ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)
ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)(EXPORT)
50,590
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
117,270
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST(AR9)(EXPORT)
SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
117,270
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYS)(INCL REM HATCH CTL) REMOTE ENTRY LK CONT(AU0)
LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
85,634
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
90,058
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
88,044
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
110,270
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
88,017
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
44,283
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
87,936
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
115,936
C9C SPECIAL PAINT OPTION (BLACK) (C9C)
49,972
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
86,688
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
108,932
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
38,764
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
101,391
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
97,270
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
39,931
IPB TRIM,INTERIOR DESIGN (IPB)
116,162
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
39,931
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
27,600
KG7 GENERATOR 125 AMP 125 AMP(KG7)
6,891
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
110,226
LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
38,764
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
86,889
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
86,889
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
105,293
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
86,406
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
102,102
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
34,884
R7A Unk. 107,831
R7R Unk. 89,718
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
117,270
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
110,237
Select only the RPO codes you want to compare for the rarity section below.
toggle allcheck alluncheck all
Rarity...
There are 7 1994 CAMARO 2 DR vehicles (0.006%) matching your exact options list. There are 17 (0.014%) with at least as many option
Old Dec 11, 2009 | 06:58 PM
86formula's Avatar
There are 1 (0.002%) with the RPO codes you selected.
Old Dec 11, 2009 | 07:12 PM
ScrapSilicon's Avatar
interesting site ..
Year: 1994
Build Date: 1994-03-09
117,270
UN6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UN6)
RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK(EXPORT) STEREO CASSETTE(UN6)
53,689
UQ0 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL STANDARD RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(UQ0)
53,489
115,914
97,792
VM3 Unk. 40,598
115,549
38,090
1AY Unk. 89,976
86,469
100,659
34,661
64B TRIM COMBINATION CLOTH, LT BEIGE (64B)
12,562
64I INTERIOR TRIM,LIGHT BEIGE (64I)
12,974
34,661
71Q MOLDING COLOR,RED (71Q)
8,702
71U EXTERIOR COLOR,PRIMARY (71U)
EXTERIOR COLOR,PRIMARY,MED PATRIOT RED (71U)
10,985
34,807
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
27,948
50,590
117,270
117,270
85,634
90,058
88,044
110,270
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
27,370
88,017
44,283
87,936
115,936
49,972
86,688
108,932
38,764
101,391
97,270
39,931
116,162
39,931
27,600
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
31,873
110,226
38,764
86,889
86,889
105,293
86,406
102,102
34,884
R7A Unk. 107,831
R7R Unk. 89,718
R8T Unk. 55,361
117,270
110,237
toggle all check all uncheck all
Rarity...
There are 1 1994 CAMARO 2 DR vehicles (0.001%) matching your exact options list. There are 1 (0.001%) with at least as many options.
Old Dec 11, 2009 | 07:16 PM
pillarpod's Avatar
Found 113,578 vehicles matching your year and model in our database.
113,578
UU8 RADIO,AM/FM STEREO,CASSETTE,ETR,DELCO/BOSE,DOLBY,INCLUDES CLOCK CASSETTE STEREO(UU8)
28,541
U65 SPEAKER SYSTEM,5,DUAL FRT DR MTD,DUAL EXT RANGE SAIL PANEL,SINGLE RR COMPARTMENT 5 SPKR SYSTEM(U65)
57,758
111,931
93,842
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
93,730
111,019
33,285
1AZ Unk. 13,876
1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 (1SK)
28,568
48Q MOLDING COLOR DK YELLOW GREEN MET (91) (48Q)
12,828
48U EXTERIOR COLOR,PRIMARY (48U)
EXTERIOR COLOR,PRIMARY,BLACK EMERALD MET (48U)
EXTERIOR COLOR,PRIMARY,DK YELLOW GREEN METALLIC (48U)
16,146
28,592
16,586
642 TRIM COMBINATION LEATHER, LT BEIGE (642)
5,603
28,592
28,817
28,817
AG1 ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2) 6-WAY PWR D/SEAT ADJR(AG1)
48,723
113,578
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
113,578
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
77,946
83,926
80,414
111,026
84,704
89,381
51,193
84,583
111,526
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
41,368
78,767
107,722
33,601
101,194
87,123
34,961
IP2 TRIM,INTERIOR DESIGN (IP2)
19,328
J1F BRAKE,SPECIAL(EXPORT) SPECIAL BRK(J1F)
99,371
34,961
33,601
111,221
33,601
87,144
87,144
105,653
78,979
99,175
QFZ TIRE ALL P245/50ZR16 BW R/PE ST TL AL3 TIRE(QFZ)
13,460
R7A Unk. 107,722
R9Z Unk. 13,804
113,578
There are 1 1995 CAMARO 2 DR vehicles (0.001%) matching your exact options list. There are 3 (0.003%) with at least as many options.
sweet site
Old Dec 11, 2009 | 07:31 PM
Colin91Z's Avatar
I guess mine is 1 of 1 also.......
Year: 1996
Build Date: 1995-08-15
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
38,947
59,439
24,620
24,424
57,327
46,692
48,140
55,948
17,310
1AY Unk. 45,847
1SJ PACKAGE - OPTION 09 OPTION PACKAGE 09 OPTION PACKAGE 09 (1SJ)
14,080
35,412
122 TRIM COMBINATION LEATHER,GRAPHITE (122)
10,422
41Q MOLDING COLOR,BLACK (41Q)
9,860
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
12,380
15,296
15,296
15,384
15,384
27,568
59,439
59,439
38,947
45,046
41,527
55,306
46,079
58,901
39,415
54,468
D82 PAINT,SPECIAL SPECIAL PAINT(D82)
13,243
17,545
52,105
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
14,586
26,421
14,577
26,421
17,279
56,722
17,279
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
6,675
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS(MN6)
6,684
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
52,105
NG5 REGISTRATION EMISSION, CERTIFICATION, FIFTY STATE (50) FIFTY STATE U.S. EMIS(NG5)
54,468
39,678
48,152
9,363
R7A Unk. 54,469
R9W Unk. 14,377
59,173
56,722
Rarity...
There are 1 1996 CAMARO 2 DR vehicles (0.002%) matching your exact options list. There are 3 (0.005%) with at least as many options.
Old Dec 11, 2009 | 10:54 PM
Johnny-LT1-runner's Avatar
Rockstar
Vehicle: CAMARO CONVERTIBLE
Year: 1994
Build Date: 1994-03-24
Found 7,974 vehicles matching your year and model in our database.
7,974
2,941
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)
7,957
7,733
VM3 Unk. 4,726
7,706
5,414
1AY Unk. 4,761
7,532
10Q MOLDING COLOR,ARCTIC WHITE (10Q)
1,041
10U EXTERIOR COLOR,ARTIC WHITE (10U)
1,436
40P WHEEL COLOR,WHITE (40P)
317
41T VINYL TOP COLOR,BLACK (41T)
7,377
6BD SPRING COMPTR SELECT FRT LH SUSP(6BD)
3,339
7BD SPRING COMPTR SEL FRT RH SUSP(7BD)
3,339
73B TRIM COMBINATION,CLOTH,FLAME RED (73B)
1,026
73I INTERIOR TRIM,FLAME RED (73I)
1,026
4,600
4,591
6,881
7,974
7,974
7,527
7,825
7,800
7,949
6,588
7,965
7,559
7,373
5,414
6,563
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
4,262
5,554
7,787
5,554
5,379
7,949
5,414
7,135
7,135
6,740
7,802
7,856
QMT TIRE ALL P235/55R16/N BL R/PE ST TL AL2 TIRE(QMT)
7,039
R7A Unk. 7,370
R7R Unk. 7,169
R8S Unk. 344
R8T Unk. 3,640
7,974
7,949
Rarity...
There are 1 1994 CAMARO CONVERTIBLE vehicles (0.013%) matching your exact options list. There are 1 (0.013%) with at least as many options.
I must say, that's a very cool site.
Oh and mine's 1 of 1!!!! That's goin in the sig now. hehe.
Old Dec 12, 2009 | 12:55 AM
brynnda's Avatar
Vehicle: FIREBIRD 2 DR
Year: 1997
Build Date: 1997-02-20
Found 27,775 vehicles matching your year and model in our database.
27,775
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
13,944
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
13,203
20,789
23,817
27,538
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)
3,371
WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
11,411
W55 ENTERTAINMENT SYSTEM OPYION E ENTERTAINMENT SYS OPT E(W55)
10,882
Y82 TRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
8,695
1SA PACKAGE-OPTION 01 (1SA)
12,835
4,783
52I INTERIOR TRIM LIGHT NEUTRAL (52I)
4,598
522 TRIM COMBINATION - LEATHER, NEUTRAL (522)
1,425
6AB SPRING COMPTR SELECT FRT LH SUSP(6AB)
3,337
7AB SPRING COMPTR SEL FRT RH SUSP(7AB)
3,337
8HS COMPONENT RR LH COMPUTER SEL SUSP (8HS) SUSP(8HS)
2,913
9HS COMPONENT RR RH COMPUTER SEL SUSP (9HS) SUSP(9HS)
2,913
AAA Unk. 26,440
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)
24,515
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE PASS SI INFL RST SYS(AK5)
27,775
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
7,077
18,133
25,089
24,745
19,876
25,584
27,775
19,873
24,508
26,440
11,411
24,874
7,843
15,688
IL2 TRIM,INTERIOR DESIGN (IL2)
7,076
15,688
11,411
25,557
11,411
21,181
21,181
24,874
15,701
N66 WHEEL,STYLED ALUMINUM STYLED WHEEL ALUM(N66)
3,371
PBT Unk. 3,371
QFK Unk. 3,371
R7N Unk. 21,467
R8V Unk. 3,108
27,775
T43 SPOILER,REAR RR SPLR(T43)
8,742
T78 HEADLAMPS CONTROL DELETE T78)
26,779
8,647
Rarity...
There are 3 1997 FIREBIRD 2 DR vehicles (0.011%) matching your exact options list. There are 14 (0.050%) with at least as many options.
Old Dec 12, 2009 | 01:12 AM
97camaross's Avatar
I don't understand the rarity part can some one enplane this is what mine said
There are 1 1997 CAMARO 2 DR vehicles (0.002%) matching your exact options list. There are 1 (0.002%) with at least as many options.
Old Dec 12, 2009 | 01:21 AM
brynnda's Avatar
1 is yours, 1 is closer than the others?
Old Dec 12, 2009 | 01:31 AM
Rockstar
It means that 1 is the only one with those exact options, therefore yours is completely unique.
The "at least as many options" means some one has all your options and possibly more if there are more options available, for example, if you had a 1LE car it would have more matches on the "at least as many options" area because it is a stripper model, therefore someone would have more options such as A/C and fog lights, but still have the same options as you.
Still confused?
Edit: Since it says "there's 1 with at least as many options" that means that yours is that one because it's fully loaded. So yours is truly 1 of 1.
Old Dec 12, 2009 | 01:34 AM
brynnda's Avatar
Still confused?
**** i am now after reading your post
Old Dec 12, 2009 | 01:36 AM
97camaross's Avatar
no I get it now. so I have a pretty rare car
Old Dec 12, 2009 | 01:38 AM
Rockstar
Exactly, yours is completely unique.
Old Dec 12, 2009 | 01:53 AM
gregrob's Avatar
This whole thread is wack
Old Dec 12, 2009 | 07:54 AM
happysem's Avatar
https://ls1tech.com/forums/racers-lo...car-1-1-a.html
Where have you guys been?
Yeah, calling BS on all of our cars being 1 of 1 or something ridiculous like that lol.
Old Dec 12, 2009 | 08:42 AM
SS RRR's Avatar
Village Troll
Right on, Brother.
Year: 1996
Build Date: 1996-03-06
There are 1 1996 CAMARO 2 DR vehicles (0.002%) matching your exact options list. There are 1 (0.002%) with at least as many options.
The rarity of your vehicle is based on an exact match of your options for your year and model.
So could I use this as a selling point?
According to SLP in 1997 there were three other cars that were the exact same as mine. Wonder what happen...
Old Dec 12, 2009 | 09:10 AM
gixxer75094lt1's Avatar
look in the glove box and inside is a decal with all the numbers on it. if yours has a ''GU5'' than its a 3.23 gear.
Old Dec 12, 2009 | 09:18 AM
chevyman9306's Avatar
why would it upset the op that he has 3.23 gears??? were the 2.73 gears stronger???
Old Dec 12, 2009 | 09:55 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I guess mine is one of five '94 models. My comparison didn't pull up anything about other cars with at least as many options.
I'm surprised there were only 8,885 six speeds out of 117,270 cars produced. That's only 7.5%. I wonder what the most/least popular colors were. Quasar Blue was on 8,051 cars, or 6.8%.
Neat site.
Old Dec 12, 2009 | 11:08 AM
I believe the op mentioned somewhere else in another thread about going with a 3.73 set and if the diff has a 2.73 set the switch would involve more $ ..but who is to say after X amount of years the diff hasn't been swapped from the GU5 setup to a GU2 ...
