comp cam question?
Old Dec 13, 2009 | 07:16 PM
slvrlt1er's Avatar
Default comp cam question?
comp 305 on 114LSA with ....510in&............510ex w/ 1.5 rockers is this cam any good or dont even wayste my time and money
Old Dec 13, 2009 | 07:20 PM
RamAir95TA's Avatar
That's an old school LT1 cam from back in the day. Cam choice depends on your goals for your car. I suggest reading the cam sticky at the top of the page.
Old Dec 13, 2009 | 08:05 PM
gregrob's Avatar
What he said. It COMPLETELY depends on your goals for the car.
I prefer a cam with a broad powerband that hits hard in the low/midrange as opposed to a large cam that sacrifices below 3500ish rpm but pulls harder on top.
Were it a drag car though, that bigger cam could be faster at the track, depending on the gearing and total setup.
I'm a big fan of the comp XFI lobes. They are very versatile in that you can keep durations low, but have a respectable lift #.
They do require a well thought out and set up valvetrain though. As should be the case with any cam you choose.
Read the sticky
Old Dec 13, 2009 | 10:32 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I had one in my blown 383 with stock ported heads & 1.6 rockers. Made over 650rwhp with a D1 Procharger. Went 10.0 in a full weight Camaro.
This cam is good for a daily driver with a reasonable idle & will actually drive along in 6th gear at 1000rpm when tuned properly.
I have a used one for sale (in near perfect condition) if interested....
plus new 1.6 Crane Golds, 7/16" studs, new guideplates etc.
Old Dec 13, 2009 | 10:35 PM
James Montigny's Avatar
There are much better lobes available in modern grinds.
Have you considered something like a a CC503 (224/230 112LSA) ?
Read this -> https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Old Dec 14, 2009 | 07:12 PM
Wooshie's Avatar
I ran that exact same cam this last year and I was very happy with it. The 114 LSA loves nitrous.
Old Dec 14, 2009 | 07:56 PM
Jazz-LT1's Avatar
I know it gets a bad rap but I just installed a CC305 in my fresh build. With ported heads and 1.6 rockers the cam has a little bit of lope (only enough to know its got a cam in it) but idles nearly stock and pulls like stink off idle. I can put it in 6th gear at 1200 rpm. I'm happy with the choice. I really don't think an extra 10 or 15hp is worth changing the car from something that drives like a nearly stock car (except having a ton more power) to something that feels like a race car.
pillarpod's Avatar
if you do it don't forget to upgrade your valvetrain
Old Dec 15, 2009 | 02:39 PM
slvrlt1er's Avatar
would this cam be for a stroker or would heads and full exhaust motor do the trick???
Old Dec 15, 2009 | 04:22 PM
StealthFormula's Avatar
The cc305 would be a tiny cam in a stroker. It's an older grind but over the years it has worked decently well for people running stock heads and bolt-ons, seems to work decent for people running power adders too. If it were me I would go with the cc503 which will act very similar but make more hp/tq throughout and have a more choppy idle (if that's what you want). Bascially it simply comes down to what your looking for from the cam in determining whether it's a good choice or not.
Old Dec 15, 2009 | 04:30 PM
slomarao's Avatar
you need to provide more info.
goals for the car?
budget?
is the car a daliy driver?
other mods done to the car?
your getting guesses and general info.
Old Dec 16, 2009 | 06:59 AM
DAVE00's Avatar
I just pulled this cam from my 383 earlier this year for a custom grind from Lloyd. As stated the CC305 is a good cam but pretty old school as this was the only (emissions friendly) cam available when I built my stroker back in 98. If you are looking for a good power spectrum and to stroke the motor I would highly recc going with a custom grind spec'd out by Lloyd. If you are leaving your motor stock (heads/displacement) then this is a pretty good cam and it's a bit more powerful then the LT4 Hotcam and also is emissions friendly. Let us know your goals and that will help better determine the cam you need/want.
Old Dec 16, 2009 | 07:18 AM
dlk1950's Avatar
Like is being said ,need to know your goals for your car. I ran it with 112 LSA for a year,see sig. Its not a bad cam very streetable.
Old Dec 16, 2009 | 01:29 PM
Jazz-LT1's Avatar
Honestly I went with the CC305 simply becuase I wanted to keep a very near stock idle because I run the car in autocross and didn't want a very noticable idle. I went with bigger valves and ported heads in order to get air into the cylinders while still having a very flat torque curve and responsiveness. Like everyone says, it TOTALLY depends on what you are trying to do with the car. That being said, if you mistakenly chose a smaller cam you are likely going to like driving it more than if you make a mistake and pick a cam that is too big and don't have the supporting mods.
Old Dec 16, 2009 | 06:49 PM
slvrlt1er's Avatar
well as far as goals i would like a nice idle, (good chop) better performance and of course more hp,and low budget, the mods on car so far is full exhaust pacesetter L/Ts SLP just statred modifing so need some help thanks guys for yalls opinions,=)
Old Dec 16, 2009 | 06:55 PM
Elliott's94Z's Avatar
Call up AI or LE and tell them your goals and get a custom grind coming your way
Old Dec 16, 2009 | 07:00 PM
GoFastKid's Avatar
^^ Exactly what Elliot said
