Fuel pressure at 20-22 max...
Turn the key on but don't start the engine. FP should jump to ~43 psi, then start to slowly drop off into the 30s. If it drops off quickly to very low numbers, you need to check for leaks. FPR diaphram, in-tank line, injectors.
Now start the vehicle. It should be ~38-40 psi.
Now pull the vacuum line off the FPR (it is located on the passenger's side of the vehicle, on the intake manifold, near the back. FP should jump ~4 psi, simulating WOT operation.
All numbers are approx. b/c of manufacturing and vehicle variations.
You can't have pressure without a volume of fuel in the lines, so I don't quite get that.
GM spec is (quote) With ignition "ON" and fuel pump running, pressure should 284 - 325kPa (41-47 psi)....When the engine is idling, manifold pressure is low (high vacuum) and is applied to the pressure regulator diaphragm. Vacuum will offset spring pressure and result in lower fuel pressure. Fuel pressure at idle will vary somewhat depending on barometric pressure but, should be less than pressure noted. (end quote)
Whether you're driving or idling, the same manifold vacuum is applied to the fuel pressure regulator. It doesn't matter.
A simple way to test for a good pump is to put a fuel pressure gauge on the Schrader valve and make it visible while driving.
Take vacuum hose off (which means pressure should be a consistent 43-45psi at all engine speeds).
Do a few quick throttle bursts/nothing crazy.
If fuel pressure dips at all below 43psi then the fuel pump needs to be replaced.
So that can't be done using a fuel pressure gauge on the Schrader valve?
