emissions
Old Dec 16, 2009 | 10:51 PM
shutzero's Avatar
The ses light does work...not sure if itts stored or pending...the guy that did the test actually works with me and told me there was no output from the rear o2s
Old Dec 17, 2009 | 07:24 AM
shutzero's Avatar
Those sims will pass me?
Old Dec 17, 2009 | 11:51 AM
AChotrod's Avatar
I dont even have rear o2s anymore. They are tuned out. I drove my car straight to the emissions place right after I put in the 355. Its the very first place I went and still passed.
Oh and IL inspections are free!
Old Dec 17, 2009 | 03:30 PM
duh's Avatar
duh
If it says your rear o2's are not responding then yes it'll fix you up nice.
Mike you got lucky with deleted programing. The current way of testing is a scanner. When the rear o2's are taken out of the program, it shows up as a non-responsive....kinda like it's not working. Therefore most of the time you need sims. Either way you passed though!!! I'm lucky I don't even need to go anymore......YEA!!!!!
Old Dec 17, 2009 | 05:47 PM
AChotrod's Avatar
I think it does say non responsive and still passed. Guy just scanned the vin, hooked it up to the scanner and the print out came back as passed, then I went and got a new plate sticker. They wouldnt give me one untill i passed even though I never got a notice to take it in for emissions. WTF up with that?
Old Dec 17, 2009 | 05:53 PM
duh's Avatar
duh
That's the new program that IL started......anything 96 and newer gets tested every year now, in order to renew your plates. All cars 95 and older get a free pass since they are OBD1.......Now they just hook up a scanner and as long as all emissions systems are functioning and there are no codes you are good to go. I love 93 for so many reasons!!!
Old Dec 22, 2009 | 07:30 AM
shutzero's Avatar
so i need to get a new tune and the o2 sims?
Old Dec 22, 2009 | 10:22 AM
duh's Avatar
duh
no, I would go with sims as they simulate the o2 working as if it has a functional cat. just make sure you wire tie them as far from the exhaust as you can and you should be good. mind you this will not help if they do a visual if your cats are gone. I'd go for the sims (it's cheaper and a sure fire way to at least get you through)
Old Mar 6, 2010 | 09:40 AM
shutzero's Avatar
these will take care of codes p0140 and p0141?
Old Mar 6, 2010 | 06:56 PM
pillarpod's Avatar
no inspections in SD
Old Mar 6, 2010 | 07:27 PM
nighthawk15's Avatar
Originally Posted by tom falco
why would you remove cats ???
clearance was one of the biggest reasons for me, but besides that its just another thing to fail and they fail a lot faster if your car is cammed or anything like that. Not to mention the car sounds better without them.
Old Mar 6, 2010 | 07:38 PM
  #32
Johnny-LT1-runner's Avatar
Rockstar
Here in the great state of Louisiana, emissions laws are non-existant. Regular inspection stickers don't even require them to look at the car.
Old Mar 6, 2010 | 08:37 PM
  #33
SS RRR's Avatar
Village Troll
My tedious emissions test is logging onto the DMV site, clicking the renew and three year option and getting my stickers through the mail. Living in bumfuck definitely has its advantages!
So I had vince tune my car went through emissions and it failed because there was nothing coming from the o2 sensors is there anyway I can pass emissions without cats? I was under the impression that as long as there is no check engine light you were golden
How long after the PCM was tuned did you try to pass emissions? Did it come back as reading "not ready"?
Old Mar 7, 2010 | 06:48 AM
  #34
shutzero's Avatar
It was probably 6 months it failed due to the o2 sensors not being active because he shut them off completely will those sims fix codes p0140 and p0141?
Old Mar 16, 2010 | 08:32 AM
  #35
shutzero's Avatar
AAnyone?
Old Mar 16, 2010 | 11:52 AM
  #36
flame's Avatar
Both those codes are for bank 1 sensor 2 which is the one after the driver side cat. Will it make you pass? Don't know what the requirements are in your state.
Old Mar 16, 2010 | 07:06 PM
  #37
EliteCamaro94's Avatar
u guys are lucky with ur 96 and up cars, i got a 94 gotta pass visual and sniffer here in az. I cant do **** to mine that i want to. I wish i would have known back when i bought it.
Old Mar 16, 2010 | 07:44 PM
  #38
literallySLOWz28's Avatar
In CT if all but 2 monitors are set it passes 96-2000.One monitor not set 2001-DATE. It makes no difference where you took the car the test is the same. Is the ses light working on the dash? Does the ecm have a stored code or pending code. If not how did the test station know the tuner tuned out the rear O2 sensors. TOM FALCO CT certified emission inspector. CT is a visual emission state. If the cats are gone you get a fail. Some testers dont look and some do. The inspector is not required to test data output of sensors. If he did that he is in violation of the law. But he can fail you on visual check NO CATS. By the way why would you remove cats ??? They dont reduce HP. In some cases it increases HP. TOM
how in some cases do they add hp? i dont see that.. i have my o2's deleted, no sims... i use the cat covers off my mom's explorer, put them around my true duals pass visual(guy looks with a mirror tide to a pole) and plugs it in and passes............
Old Mar 16, 2010 | 09:48 PM
  #39
shutzero's Avatar
So the driver side post cat o2 should be the only one I need to replace?
Old Mar 17, 2010 | 11:41 AM
  #40
flame's Avatar
That is what the 2 codes you listed are for
