MSD Optispark
Old Dec 17, 2009 | 02:50 PM
thebeast93's Avatar
Default MSD Optispark
I just bought a MSD opti for my 93 camaro and it came with vacuum lines to plug into the intake manifold and the elbow, but I cannot find where. Can someone help me
Old Dec 17, 2009 | 03:09 PM
Schweet97Z's Avatar
The MSD opti is vented. You stocker is not. You have two choices. Either cap the vent hole on the opti, or run a rubber hose to your intake elbow... Id choose option 1.
Old Dec 17, 2009 | 03:53 PM
Puck's Avatar
Don't cap the hole! The defeats one of the biggest benefits of an MSD cap on a 92-94, the cheap conversion to vented.
Just drill a small hole in your elbow and run the other cap vent with the "T" and check valve provided into a vacuum port on your manifold. Viola - instant vented opti.
Old Dec 17, 2009 | 03:57 PM
31camaro's Avatar
x2, it comes with instruction when you bought it
Old Dec 17, 2009 | 08:45 PM
ElkySS's Avatar
^^yup
Old Dec 17, 2009 | 09:10 PM
shbox's Avatar
I thought the things came with complete instructions on how to run the vent hoses. They are on MSDs website.
http://www.msdignition.com/instructi...pdf?terms=8381
Old Dec 18, 2009 | 06:40 AM
Schweet97Z's Avatar
That debateable...I realize what a vented opti is and all about. However ive seen plenty of non vented opti's live a very long and healthy life.
Old Dec 18, 2009 | 06:45 AM
96capricemgr's Avatar
If the guy were capable of searching the web for information he would have realized the MSD opti is a bad thing, much more expensive and less reliable than stock.
The cap and rotor kit is nice and would have allowed the conversion to vented that the one rocket scientist here is saying not to do.
 Michael S. Palmer
Old Dec 18, 2009 | 09:13 AM
pillarpod's Avatar
I love my MSD opti
Old Dec 18, 2009 | 05:50 PM
Originally Posted by pillarpod
I love my MSD opti
Your signature proves you don't know enough to comment intelligently on what is an is not good parts.
Old Dec 18, 2009 | 06:00 PM
93v8clone's Avatar
lololololol
Old Dec 18, 2009 | 06:31 PM
ElkySS's Avatar
well i have seen just as many complaints about the msd as the gm one. also as many people that think either one is great. the thing i like about the msd is its rebuildable
Old Dec 18, 2009 | 07:20 PM
How many more GM ones are out there than MSD? How many MSDs have made it to 100K and beyond?
Old Dec 18, 2009 | 07:53 PM
stevo9389's Avatar
1. its safe to assume there are alot more GM ones since they have been made since 1992
2. the MSD opti has only been around since what? 2006? is that even enough time for it to get the same 100k mile treatment as the GM ones?
Old Dec 18, 2009 | 08:01 PM
BOLO's Avatar
MSD have great quality products and racers of all levels have proven their products performance. I'm sure their R&D team did their homework when they made their LT1 optisparks.
Old Dec 18, 2009 | 08:13 PM
litch2004's Avatar
i have had problems with mine. Within 2 years the rotor arched out on the shutter wheel. If it f's up again im going back to the Ac Delco or converting to LS1 PCM
Old Dec 18, 2009 | 09:03 PM
Speedy's Avatar
It has been a long time since I installed mine, but if I remember, you should have a white t-bar adapter that came with the MSD unit. On the driver's side of the manifold there is a small rubber 5/16" hose next to a larger EGR hose. Install the t-adaper on the 5/16 hose and route it to the bottom of the MSD unit. The top hose will run to your air intake. You must puncture a small hole in it and install the elbow there. Make sure it is a snug fit.
It is important to install the vents because they remove several things from the distributor, including seeping oil from the timing chain cover, acidic gases that result in premature failure, smoke that can obscure the laser, and any moisture that may accumulate. Make sure you check the optispark vent hoses for leaks on a regular basis because if they crack your MSD will suck up water in a rain storm and the car will stall out.
Some guys don't like the vented optis. My first unvented opti lasted 90,000 miles, no leaks. I have found in most cases optis fail because of bad installation, and leaky hoses.
