Clutch problems!
Car: 1995 Z28 M6 w/spec stage 2, B&M short throw
What happened:
- Revved up, slipped the clutch, and launched
- Lost traction, finally caught at the top of 1st and took off. Nothing new or weird
- Pushed in the clutch to shift to second. Good pressure, but it doesn't allow me to go into 2nd.
- No pops, squeals, squeaks, loss of pressure, etc.
Pedal feels normal and tranny shifts great if I gear match. If it's in neutral and the car is on, I can put pressure on the shifter towards the first position and it'll creep forward, if I let up, it stops moving. It won't go into gear unless the car is off, even with the clutch pedal pressed in.
If the car is running it will NOT go into gear. If the car is off, it WILL go into gear. If I gear match while the car is running, it WILL go into gear.
I really doubt its a spec stage 2, with your mods i dont know how it could break.
93TAJ.C. said that the friction disk may have split (if it was defective I'm assuming), and that is a very possible cause. But if I were you I'd check and make sure your hydraulics are working properly first, like what nik1703 said. Just because there's no fluid leaking from the master or slave doesn't mean there's no internal leak in one of the two. I can say from experience that I've had this problem-- even though my pedal felt normal I ended up having a faulty master cylinder.
The slaves cheap and easy to replace, so maybe try that first. If thats not it move on to the master, which is a bit more expensive and tricky to replace. Also make sure you bleed the system whenever you crack it open.
As for the clutchfork, even when its fully engaged its gonna have some play in it. You can move the arm up and down a tiny bit and the other ends of it will just tap the surface of the throwout bearing. There will be some forwards to backwards play too-- you'll be able to pull it backwards a tiny bit, but when you push it forwards itll go freely until the fork tips press against the collar of the throwout bearing. Then at that point you can't push it any furthur simply because your fingers aren't nearly powerful as the hyraulics are.
I doubt the clutchfork is actually loose. By the way our clutches are setup, if the bolt that holds the clutchfork to its pivotpoint on the transmission were loose the hydraulics would push the clutchfork so far that it would scrape against the spinning pressure plate. This would give you disengagement problems like youre having, but it would also make a ridiculously loud screeching noise while the engines running.
Hope that helped and good luck.
Is there a way to check this without pulling the tranny? Like I said, it's extremely freely moving, so I kinda think this might have something to do with it. It's to the point where I have to hold everything in place while I put it together. There aren't any noises. There weren't any noises before, after, or during the time it broke. And it went from everything perfect, to just absolutely nothing.
Sorry if I'm going in circle, just a little frustrated with the car. Thanks for all your help!
