O2 sensors
Which o2 sensors control the fuel at all? Is it the back two or the front two? I have a 1997 z28. It seems when its warm it runs really rough so I was wondering if those are causing it which two it would be. Also if I unplugged them what exactly would happen after the engine was warm? I get crappy MPG atm. I believe around 11-12 city with no hwy driving. Thanks in advance.
Front o2 are the ones that control that. I think it should run how it is when its cold. If not then u may have other problems.
EDIT: oh and ur SES light will come on after a while.
I think its rich after its warmed up. I think thats why my MPG really sucks and why after warm the car runs rough at idle. I could be wrong but it seems to be from there since it runs better when the engine is cold compared to hot.
How many miles on the car? If over 60 change them. They should be part of your preventive maintenance. Use only AC Delco / Delphi..
Clean your maf sensor and inspect for signs of damage.
Do the ICM cooling mod.
Tuneup if it hasnt been done.
If those things dont fix your mpg and rough running problems you can keep looking but they are all good things to do anyway.
