Mr gasket head gaskets
Old Dec 28, 2009 | 09:06 PM
ladybird's Avatar
Cool Mr gasket head gaskets
Is anyone running the Mr gasket head gaskets on their LT1z? When I bought my heads the guy I bought them off of suggested I run those gaskets to slightly bump up my compression do to the fact that their thinner than the stock ones. Anyone have any thoughts?
Old Dec 28, 2009 | 09:10 PM
James Montigny's Avatar
I've run them on several builds, no problems at all.
Now that I have a zero-deck block, I run thicker gaskets.
In retrospect, a .005" deck and .026" gasket probably would have worked out better.
Old Dec 28, 2009 | 09:31 PM
AChotrod's Avatar
I run them! 5716s havent had a prob yet!
Old Dec 28, 2009 | 09:36 PM
Torque Fiend's Avatar
I bought them, but haven't yet installed them. Everyone from what I read has liked them and no problems.
Old Dec 28, 2009 | 10:04 PM
robsquikz28's Avatar
They are good
Old Dec 29, 2009 | 12:18 AM
JAKEJR's Avatar
I put them on my son's 96 Vette 5716 IIRC. No problem.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 29, 2009 | 12:58 AM
airfix's Avatar
I have the 5716 on my car also.
Old Dec 29, 2009 | 03:42 AM
96LT1355Z28's Avatar
Same here!
Old Dec 30, 2009 | 10:02 AM
harner's Avatar
Will the 5716s work alright on a stock bottom end/stock headed car with cam only and new PR/1.6RR/springs? I also plan on running a 150 shot max on occasion.
Valve clearance should be ok?
Old Dec 30, 2009 | 12:23 PM
You won't have PTV issues with an Lt1, not in any reasonable street build anyhow.
The head gaskets will be fine.
Old Dec 30, 2009 | 01:13 PM
AChotrod's Avatar
would it be enough diffence to need new PRs?
Old Dec 30, 2009 | 01:17 PM
No .051 - .026 = .025
But thinner gaskets plus shaved heads and LS7 lifters would.
Old Dec 30, 2009 | 01:18 PM
AChotrod's Avatar
Got ya! Didnt know how thick stock gaskets were.
Old Dec 30, 2009 | 01:38 PM
No problem, also keep in mind that the pushrod does not sit perpendicular to the deck,
so .025" shorter quench only impacts the pushrod by maybe .017"
not enough to make a step from 7.200" to 7.150" on it's own.
Old Dec 30, 2009 | 07:03 PM
harner's Avatar
Thank you for the info!
Old Dec 30, 2009 | 09:23 PM
MattSapp95_T/A's Avatar
I run Victor Reinz pt# 5898 I bought them for $47 to my door for the set...
they are the same .026 specs as the Mr. Gaskets but packaged better and half the price...
Matt
Old Dec 30, 2009 | 09:33 PM
transam5.7lt1's Avatar
Matt
Isn't that brand low quality gaskets? I ask because I've seen other gaskets made by them for water pumps, valve covers and timing covers and let me tell you that they look like were made out of a kellogs box........
Old Dec 31, 2009 | 03:49 PM
No.the part number I listed is identical to the Mr. Gasket ones...I have heard a lot of complaints too about how poorly the mr. gaskets are packaged....There are a ton of guys on here using the Reinz with no probs...
Old Dec 31, 2009 | 04:46 PM
djjab57's Avatar
My Motor guy and my head guy (L.E.) both recomended the Mr Gaskets
