7000 RPM - keep opti or go another route?
94Z28rag- I must have missed all the people with broken stock timing chains. I apologize for my ineptitude.
LT4 block huh?? A tuner that resists tuning it with an opti?? I don't see this going well for you.
It is mostly the ignorant that have opti problems and swear it wont work. You say the stock opti is not known for lasting on high rpm stuff on the b-body boards BUT Jeff Green, Mike Harris, Pat Gish, Karl Ellwein, Nabil Guffrey, myself and a lot of the other guys with cars that perform well enough to be noticed use the stock opti.
last I heard the Dynaspark used a LOT of stock parts and as I already covered the LTCC still needs a functional opti base.
IMO most opti problems are self inflicted, be it neglect or other contributing problems. Too many of us taking to way up in the rpms without issue to be blaming the parts alone.
One more thing. Talked with dynaspark a while back and each unit is usaully built upon request. Not sure who supplies the cap and rotor for them but it appears to be of vary high quality.
I'm going with the ltcc setup on my build. Stroked forged lt4 block trickflow heads and the infamous mease/eaton supercharger setup. On the b body forums the opti isn't known for lasting in high rpm setups. Maybe it's different for the f body guys. My tuner doesn't even want to tune it till I swap over to the ltcc.
