why doesnt my cc503 sound like yours????
LOL yes you did i dont remember you either but i remember your car lol..
ill check out that thread any upcoming meets
and thanks i like your ride too.. im more of a bird guy but i always have a soft spot for a red camaro
come by sometime i can probably hook up some kind of discount and we are pretty much the only auto parts store that sells quailty stuff like moog and standard motor products and basically all the performance stuff lol
but yeah im feeling a portland meet coming up ha
You might want to pull the IAC valve/motor housing off the bottom of your throttle body and give it a good cleaning. DON'T pull it off if you haven't done the throttle body bypass or you'll spill coolant (on a stock TB with water cavity). If you have done the bypass and this is an upgraded TB, you might want to make sure the blades are closing completely. Air getting by a zero throttle will cause it to idle high, as high as 1200-1500 RPM.
I don't think it's your magnaflow entirely... Your lope has a lot to do with RPMs and the fuel settings. My tuner dropped the RPMs a little and leaned it out a bit at idle so I could get the idle I wanted. Admittedly, I wanted the lope whether it was better for performance or not I bought the cam for a loping hot rod, not for a drag strip queen that sounds like a stock car.
I can't pull it up here at work to get you the link but I have a video in my youtube titled "Did someone order CC503 lope?" and it's a clip of my exhaust running through my V6 (smaller diameter I pipe) Magnaflow exhaust and then I opened my Race Ready Performance electric cutout about halfway through the video.
http://www.youtube.com/mifbody/
No, never....
http://www.youtube.com/watch?v=gCzPJxtjrZw
The camcorder mic has it muffled some... it's loud.
Definitely louder than when it had a FLowmaster on it.
#35
Well out of the several guys on here from past threads and that I know in my hometown, can tell you it is one of the more quiet catbacks. Flowmaster and GMMG are both louder then the Magnaflow. My buddy has the Flowmaster (which is a good deal louder) and the GMMG speaks for itself. Do a search through old post and you will find that a lot of guys say if you want a quieter catback then get a Magnaflow. And if you are implying in your last statement that you can't blame his catback for hindering some of the sound then you aren't up to par on some of this stuff
#36
I ran the magnaflow at one point on my LE set up and it was the quietest catback/exhaust I have ever heard or ran. It really made the camshaft seem almost factory. Switching to TD's made the cam come alive. Black93...you are in need of some product knowlegde my friend.
#37
idk what you guys are talkin about my magnaflow at idle is dam quiet but when you get in rpm's it really opens up but elliot is right they are quiet and i honestly think it is becuase of the magnaflow ...
it cant be the tuner fault cuz its solomon right and he has my car dialed in right now
#38
amen brother lol
