What is the part called?
Old Jan 5, 2010 | 04:27 PM
fire-chickens's Avatar
Default What is the part called?
This plug or breather thingy on my valve cover is seeping oil, and was wonder what it was called or where i could find a new one.
its circled in the picture.
Old Jan 5, 2010 | 04:29 PM
djjab57's Avatar
PCV valve i believe, any auto parts store
Old Jan 5, 2010 | 04:32 PM
what does it do any idea?
Old Jan 5, 2010 | 04:33 PM
RamAir95TA's Avatar
Wrong.
The PCV valve is located on the driver side of the intake manifold. He is looking at the fresh air supply hose for the crankcase.
OP, you can remove it and replace it with a breather available at most parts stores, or replace the hose/grommet (also available at most parts stores). If you opt to remove the tube, make sure you plug the large fitting left on the throttle body.
Old Jan 5, 2010 | 05:38 PM
Smoke Em's Avatar
does it do anything if you replace that hose with a breather? and cap the TB?
Old Jan 5, 2010 | 05:40 PM
67goatman455's Avatar
that is a very interesting debate. you will have to come up with your own decision
Old Jan 5, 2010 | 07:49 PM
well i pulled the plug thing and it was just like a plastic hose that just kinda went into the hole, theres no rubber grommet or anything, although its letting a lot of oil seep through. it wasnt he pcv valve but I'd still like to fix this oil seepage somehow.
i did actually buy a pcv valve and just replace it anyway even though the old one still rattled, it looked pretty crappy like it was original and it was only 3 bucks, may as well replace it.
Old Jan 5, 2010 | 07:58 PM
is that part supposed to have a rubber grommet on the end of it, kinda like on the chevy trucks of the same year?
like this one in this picture(shape may not be exact)
jetblack93's Avatar
get chrome valve covers then done
Old Jan 5, 2010 | 08:00 PM
stevo9389's Avatar
if you go with a breather make damn sure that thing is secure. after losing 4 of them i put the stupid hose back on.
Old Jan 5, 2010 | 09:00 PM
i dont want to go to a breather, i jsut want to fix the dang oil seepage from the valvecover, where the arrow is pointing. idk what that part is called still or why its seeping.
Old Jan 5, 2010 | 09:26 PM
transam5.7lt1's Avatar
I had a 1994 LT1 and it had 2 PCV valves, one on the drivers side of intake manifold, the other one where you circled in the picture.
Old Jan 5, 2010 | 09:34 PM
well i looked in the haynes manual and it said the only pcv valve is the one that goes into the intake manifold, the part i circled wasnt even mentioned, its like the problem i had on my '94 chevy with the tbi305, the grommet seeped oil so i replaced it and all was good, but so far i hav't gotten a difinitive answer, the part i circled is definately NOT a PCV valve looks nothing like one, its like a plastic hose that pops into the hole with a ring thats supposed to seal it, its got a 90 degree angle to it.
Old Jan 5, 2010 | 09:44 PM
chevymec's Avatar
I called it a breather when I called the dealer and ordered. I need to call and see if it came in to.
Old Jan 5, 2010 | 10:14 PM
RamAir95TA's Avatar
Just bring it to the parts store and look for a grommet that will fit.
Also, I explained in my first post about what the tube is.
Old Jan 5, 2010 | 10:53 PM
Camaro350z2897's Avatar
^^ agree here.
it is not 2 pcv valves. pcv valve is on driver side in manifold. the one on the passenger side is just a fresh air tube like said. it provides circulation through the throttle body. get a new grommet make sure the plastic fitting fits tight and it should help the seeping.
Old Jan 6, 2010 | 01:40 AM
LT1's Avatar
LT1
Like some have said, replace the grommet and the 90 degree tube.
Its probly worn out, dried up, cracked and not sealing properly.
Old Jan 6, 2010 | 07:05 AM
shbox's Avatar
Then someone that did not know what they were doing put it there. No valve goes in the valve cover.
Old Jan 6, 2010 | 10:10 AM
djjab57's Avatar
well i dont know what its supposed to be called but when i went to AZ and picked it out of the parts book its called a PCV and also said it on the package
Old Jan 6, 2010 | 10:18 AM
RamAir95TA's Avatar
To whoever's credit, the hose is an air supply hose that supplies the PCV system with MAF-metered filtered fresh air to displace crankcase gases. That's probably why it said 'PCV' on it. Just a tube, an elbow, and a grommet.
More importantly, it's not a PCV valve.
