got my first lt1
long term goal is to go after the lt1 bolt on record and then after that she will get a 1st gen small cube n2o engine in here for some 275 action.
but so fair all she has is the k&n filter kit and elbow..i was just going to make my own but i guess i got it..going to get the pace off road headers for it..because once i get the mass state inspection done..so then she will be getting them to bullets an ill block off the egr and ditch the a.i.r...i read some where the a.i.r wont throw a code but the egr will for my year?
the abs op light is on right now and im not sure if i will fail do to that but im planing on ditching the abs and just putting in a portioning valve in her..the guy told me it needs brakes.
also going to get eletric water pump..not sure what to get though..i see summit sales there own sort of knock off one..going to hook the fan up by switch..and then do weight reduction from hell..looking to get it down to 2800 with out me and stock brakes and glass with gutted dash and 1 race seat.
i know theres the free mod list witch i been looking over..once it warms up ill loop the power steering pump and put skinneys on and ditch everything up front but the alt..
any advise for these things? im planing on keeping the 10 bolt and sticking 4.56 gears in it..anyone know what carrier these 10 bolts are?
thanks for the info and im glad to join the lt1 group..lots of good info on this site.
anyone got the weight differece on the sunoco vfn hood wide or reg i cant really tell a diffirence between the 2 but vs a glass tech 4" cowl? i cant decide what one i like and what would be better for street use and give me more engine space seeing later ill have a pretty tall carb,n2o plate and carb setup under it an dont want to run into haveing to cut the hood to gain carb clearance..
as for the car im coming from..this is my 8th camaro..ive had 2nd,3rd and 4th..but my last 4th had a 327 in it that made 750hp on juice and i also built a sb2.2 n2o combo for it that made 880hp on motor....im only doing the bolt on record till i build my other engine for 275 d/r stuff..it will be a 33xci juice engine on a 300 shot and ill have to be 2900#s..should run mid 8s
my first mods are going to be pace setter off road headers/a.i.r delete an egr,then go right to bullet mufflers...who has the best deal on here for headers..i seen some for 260 i thought an jegs wants 310 i think
does anyone know the part number for the a/c 1le delete setup so i can go get it an the correct belt to use.going to do ac delete but keep my heater an make my own block of plate..i figure this will be eaiser when im bout to swap to headers
then im also going to get a 3rd gen proportioning valve an delete my abs..
and that somes up my first round of mods along with weight reduction. Thanks for all the help and info on this site..
I installed a Meziere on my car two years ago. It was one of the best things I ever did. They are a little pricey compared to the summit/jegs brands and the CSR, but it is definitely worth it. Pay high once, rather than buy cheap twice. Meziere gave me great customer service and the pump comes with a five year warranty.
My temp rarely fluctuates and its a real nice plus that I can hook the pump up to a switch for when I start taking the car to the track more.
Year: 1994
Build Date: 1994-02-10
Found 117,270 vehicles matching your year and model in our database.
RPO Description Matches Compare
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
117,270
U1T RADIO AM/FM STEREO, SEEK/SCAN, COMPACT DISC, HPS, CLOCK, ETR STEREO/BOSE(U1T)
29,904
U73 ANTENNA,FIXED FIXED ANT(U73)
115,914
U82 SPEAKER SYSTEM 3, DUAL DR MTD, RR PKG SHELF 3 SPKR SYS/BOSE(U82)
63,581
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
97,792
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
115,549
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
38,090
1AZ Unk. 22,834
1SC PACKAGE-OPTION 03 (1SC)
86,469
14B TRIM COMBINATION - CLOTH, GRAY (14B)
41,680
14I INTERIOR TRIM LT GRAY (14I)
41,680
17P WHEEL COLOR-SILVER (17P)
100,659
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
19,670
6HD COMPONENT FRT LH COMPUTER SEL SUSP (6HD) SUSP(6HD)
34,661
7HD COMPONENT FRT RH COMPUTER SEL SUSP (7HD) SUSP(7HD)
34,661
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
34,807
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
27,948
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)
66,680
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
117,270
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST(AR9)(EXPORT)
SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
117,270
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYS)(INCL REM HATCH CTL) REMOTE ENTRY LK CONT(AU0)
LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
85,634
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
90,058
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
88,044
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
110,270
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
87,936
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
115,936
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
86,688
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
108,932
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
38,764
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
101,391
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
11,115
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
39,931
IPB TRIM,INTERIOR DESIGN (IPB)
116,162
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
39,931
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
31,873
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
110,226
LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
38,764
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
86,889
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
86,889
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
105,293
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
86,406
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
102,102
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
34,884
R7A Unk. 107,831
R9Z Unk. 21,627
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
117,270
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
110,237
