dropping my motor so many problems
Also like 1badz said, disconnect the torque arm at the differential side, and then slide toward rear of car while pulling end from the soft mount located on trans.
I also did not leak fluid when loosening the bolts to master cylinder, to gain access to hex nut. When your putting bolts back later put hex on passenger side to prevent that problem in the future.
Success!!! Thanks, got a few more questions for you if you can?!
I cant get to this torx bolt with the bit i have, if i remove the brake cylinder from the booster no fliud should leak out right, i don't have cash for a new pain job
and i disconnected those wire... sorry you guys maybe a picture of my goofy *** girlfriend could help??!
Resume thread.
