dropping my motor so many problems
Old Jan 12, 2010 | 09:28 AM
boostedpower's Avatar
Default dropping my motor so many problems
Okay im dropping my motor from the bottom, i was told to remove the drive shaft rather than disconnecting the trans from the motor, so first step (basiclly not really) remove the driveshaft, only theres so much **** in the way and my car is on the 2 tires and i cant rotate the drive shaft to get to the other side, does it reall nnot make sense to disconnect the trans from the motor?
Old Jan 12, 2010 | 09:32 AM
nomoneyz's Avatar
Its just a pain in the *** to remove the trans first. Makes it alot easier to do it all at once.
Old Jan 12, 2010 | 09:54 AM
1badzee's Avatar
Best thing you can do is jack up the rear and rotate the tires and get that driveshaft out. It's real easy to drop the k-member. Just make sure you disconnect the brake lines from the ABS unit.
Old Jan 12, 2010 | 10:05 AM
Okay so im about to just unbolt the trans and softly lay the driveshaft on the floor after the yoke slides out from the transmission and motor coming out, theres seriously no way for me to unbolt the driveshaft with out it rotating ITS JUST NOT POSSIBLE! and I feel that I have removed far to many things for this to be the right way, people say they drop motors in 3 hours, its taking me a week and its still not out, ive done everything disconnect the electrix, drain oil coolant trans fluid, (removed the intake manifold) coolant resivior, batt., strut towers, working on the exhaust, intake and all the **** that goes with it, radiator, fan, disconnected the A/C lines, can anyone give me some hints to make this go faster i don't see how its possible in 3 days let alone hours!!!
Old Jan 12, 2010 | 10:07 AM
yeah I made sure to get the rubber caps for the ABS... but seriously, subarus, and hondas are like legos, WTFFFFFF!!!
Old Jan 12, 2010 | 10:08 AM
I needed to take a break so im taking a nap and hoping when i wake up there will be tons of hints because im about to throw my socket threw the window!!
Old Jan 12, 2010 | 10:13 AM
1badzee's Avatar
Relax man.. What do you mean the driveshaft keeps turning? Pull the e-brake up and make sure the transmission is in park - it won't spin. There was no need for you to remove the intake manifold, radiator, coolant reservoir, fans or any of that.. The a/c lines, transmission cooler lines, power steering hoses (from reservoir) and brake lines should be the only "lines" that need to be removed when dropping the motor. Then of course the engine harness, remove shifter cable, driveshaft, etc. Then unbolt the tranny crossmember, sway bar bolts, 6 k-member bolts (rest the engine/kframe on a jack or something), then unbolt the strut tower bolts (should be 4 on each side, two of them might be a torx bit). I couldn't tell ya why it has taken you this long and still not done.
P.S I've done it at a junkyard with the most basic hand tools (and the help of a friend) in ONE hour.. Let me know if you need to know anything else..
Old Jan 12, 2010 | 10:42 AM
the_merv's Avatar
Veteran: Air Force
Ya I'm confused aswell..I can get mine out the bottom myself in about an hour..
Not tryin to brag..we are just tryin to figure out where your snag is. Just don't get in a hurry and flustered and un-bolt the K-member and drop the thing on your chest.. it'll be like droppin a fat chick except without the cushioning..
Old Jan 12, 2010 | 10:49 AM
I relize now i have to somehow jack up the back end (use some blocks of wood) to turn the drive shaft to get to the 4 bolts that hold the shaft to the diff. and try and squeeze it through the exhaust and w.e. that long black bar that runs parallel to the shaft, this just turned out to be more of a project then I though and its 30 degrees out so Im a little irratable, plus im doing this in my garage with hand tools... thanks for the help you guys, tips are always welcome
Old Jan 12, 2010 | 10:50 AM
and merv thanks for the joke, much needed, what exactly do you remove when you drop it how is that possible i've been working my *** off
Old Jan 12, 2010 | 12:24 PM
BadBlackZee's Avatar
Sounds like you left the torque arm on (long black bar running parallel to the DS). You are going to have to remove that to pull the motor. Plus, its much easier to get to the DS bolts with the torque arm removed.
It should be fairly straightforward to pull the motor...as 1badzee stated. Him and I removed a motor in about 1-2 hours from a junkyard. Just take your time, use logic, and think things through. I know you might be tempted to rush....
Old Jan 12, 2010 | 12:38 PM
AChotrod's Avatar
A week and its still not out?
Old Jan 12, 2010 | 01:20 PM
RamAir95TA's Avatar
I'm pretty sure I sent you this link once already...
http://www.michiganspeed.com/enginepull/index.html
Old Jan 12, 2010 | 01:22 PM
I8ASaleen's Avatar
Give him some slack. Mine was sitting for 2 years without headers b/c I was lazy
Old Jan 12, 2010 | 01:24 PM
RamAir95TA's Avatar
The information he needs has been given to him though.
Old Jan 12, 2010 | 02:15 PM
the_merv's Avatar
Veteran: Air Force
Unbolt Exhaust, disconnect D/S, drain and pull Radiator, disconnect Fuel, Brakes, Steering Linkage, and all Coolant Lines, disconnect Grounds, unbolt Tranny Crossmember(it helps with the UMI T/A Relocation Kit..it comes apart really quick), unbolt Front Sway Bar off of Frame Rails, unbolt lower Struts, Upper LCA Ball Joints, lower the Car and place K-member on Jack Stands..disconnect all Wiring and unbolt the K-member, and it's down and out.
No AC cause it's deleted, and Power Steeing comes with the Engine on the Cradle..I love that, trust me..
Last time it came out and went in through the top..that wasn't too bad either..took a little longer though.
Damn lazy ***..lol
Old Jan 12, 2010 | 06:54 PM
Okay so everything is unbolted, trans mount, cat, but the drive shaft doesn't want to come out of where its bolted to the diff. (i removed the u bolt) So should i drop the transmission or should the driveshaft be able to come out before the tranny is dropped
Old Jan 12, 2010 | 06:57 PM
RamAir95TA's Avatar
Remove the four bolts holding the u-joint straps, then tap the driveshaft toward the transmission. It will slide into the transmission slightly, then drop it down and pull it out. Be prepared for fluid to come out of the tailshaft.
Old Jan 12, 2010 | 06:59 PM
Thanks man i have my laptop under the car with me ill past in a few minutes!!
Old Jan 12, 2010 | 07:00 PM
<--- heres what it looks like btw
