tranny question behind built motor
Old Jan 13, 2010 | 05:08 PM
whammer33024's Avatar
do you guys think a performabuilt level 1 would be healthy enough for me?
i'd consider doing the th350/400 swap but i just don't know enough about it and am afraid i'd really mess something up. a built 4l60e is just a plug and play so i think that would be the simpler route to take
Old Jan 13, 2010 | 05:29 PM
quews6lime's Avatar
it should be ok for wat u r tryin to do the weekend thing and the car shows....but if u race it build it
Old Jan 13, 2010 | 10:55 PM
the_merv's Avatar
A stock one would be fine if he just plans to grandma it around..I don't see that happening though.
Old Jan 14, 2010 | 09:44 AM
do you guys think a level 3 4l60e from FLT would be enough as well?
Old Jan 14, 2010 | 09:51 AM
1badzee's Avatar
^ I don't see why not.. And a TH350/400 is plug and play also.. Nothing you can mess up. No custom work or anything lol
Old Jan 14, 2010 | 10:10 AM
how much do you have in your th350?
Old Jan 14, 2010 | 10:13 AM
1badzee's Avatar
About $1,500 in the whole swap (tranny, crossmember, converter, driveshaft, shifter/cable,). I already had things such as a tranny cooler, a/n fittings and stuff (which is cheap stuff anyway).. I went through 2 transmissions (4L60's) before I decided this is what I need..
Old Jan 19, 2010 | 02:38 PM
what size converter do you think i'd need for the th350? who makes them? i own an auto parts store so getting the random odds and ends is rather simple for me, lol. you can't re-use the 4l60e's shifter? if i got
i see re-built 350's going for about 600 on ebay...and 500 or so for a converter...then whatever a crossmember costs...so i'd be looking at 1500 or so anyway...which is about the same as performabuilt level 1...
now most of the people around here are old school hot rodders...so i'm thinking i could find a 350 for rather cheap, but would a stock shifter cable from the 350 work? would a stock rebuild be enough to handle my engines HP or would i need upgrades?
Old Jan 19, 2010 | 05:43 PM
AChotrod's Avatar
M6s are not bulletproof by any means, and more expensive to rebuild. Ask me how I know !
