tranny question behind built motor
as some of you know, i blew up the stock engine in my car. well i just purchased a 396 lt1 from jason short right here on this forum. pretty stoked about it to say the least. the engine has been dyno proven to make 415rwhp and with some changes can see up to 450rwhp NA.
now my question is, this engine is costing me pretty much every penny i got. i have a stock 4l60e with an ss3600 converter. my car is not a racecar whatsoever. basically its going to be a show car/weekend cruiser. is the stock tranny going to be okay or am i just being dumb? lol. i plan on buying a tranny in the future, but the funds just aren't there right now.
what do ya think?
im so jealous
thanks speed#1! i'm pretty excited about it. he basically built the exact motor i'd build if i had the money, so when i saw his price i immediately jumped on it.
now if i did a th350, will i have to change anything inside the car such as shifter or console or anything? is that tranny good for highway speeds as well or should i look for a 4l80e?
tranny crap is brand new for me so i'm trying to learn as much as i can right now and a lot of the info i read is about ls1's
A TH350 is a 3-speed transmission without overdrive, so I doubt that's what you're looking for (not to mention lots of things need to be changed).
I recommend Performabuilt. They built me a bulletproof 4L60E that I regularly beat the snot out of.
hopefully that explained it a little better. as i said, my stock motor took a dump and i needed to get something done now before spring gets here so i figured why not buy the motor i really wanted? i was looking for a less built 355 but jason put the 396 up and i HAD to jump on it. sorry if i you guys think i'm an idiot i guess
Now, if you can afford to dish out the money for a built 4L60E, I say go that route so you can retain overdrive. I personally didn't have the funds and I would much rather have a TH350 because of the simplicity and the strength (not to say a 4L60E can't be built strong, it just costs more).
****..you'll change your mind about cutting if your Fuel Pump goes out, I promise you that..
The main reason I switched to the T56 was cause my Engine was shredding built 4L60E's..I got tired of having them built every 4 months and invested into a T56 with a Good Clutch and good Shifter. I kept the T56 stock and when it broke(stripped 2nd Gear..
) I tore it down myself and rebuilt it with a bad-*** kit..now it will last a good long time. Ya I could've went with a 4L80E, but I figured that it would be wiser to invest into something that I could do myself and that was durable..and a **** load more fun..
BTW what heads/cam are in that 396?
