what are the exact rules for bolt on record?
Old Jan 14, 2010 | 08:16 AM
tomcowle's Avatar
I did this both ways, first carb (which everybody said wouldn't work) and then fuel injection after everybody said the carb (even though it was a factory LT1 carb) wasn't cool now. Its just a internet record, something to gauge your cars performance against, thats it.
It was cheap fun for me and fun to beat up on more highly modified cars. I think I had less than 4k in the entire car including license and insurance. I bought 95 percent of everything used from members here and met some good guys along the way.
Tony, the lt4 carb manifold doesn't match, you need the lt1 carb manifold made by GMPP.
Rebuilds are out, so is pulling the heads (especially for performing a valve job and installing a thinner gasket for more compression) and of course no gasket matching, porting or polishing. Factory assembled longblock.
As far as the carb versus efi thing, I was on a chassis dyno several times with each trying all sorts of stuff and honestly they are damn near equal in terms of power and torque. EFI was stronger in the middle, carb was stronger up top but average hp was about a wash.
Old Jan 14, 2010 | 10:00 AM
95 Formula's Avatar
Originally Posted by suicidal racing
im sure a ported or port match intake would make more power..but from what i under stand is a ported intakes are a no no..ill pm tom tomarrow on a diffrenet site and see what he says for rules seeing after all he is the current record holder...
if ported intakes are a no no do you really think that changing the complete intake and switching to a carb would fly for this internet "record". Just put a carb on the car if you want and have fun and just don't worry about the internet record.
Old Jan 14, 2010 | 11:19 AM
RamAir95TA's Avatar
Seems like this guy fights battles for everyone else. Tom said this, this guy said that, etc.
Old Jan 14, 2010 | 11:35 AM
95 Formula's Avatar
yes most think converting to efi is a bolt on..intake and rails bolt on to the engine.
so does a blower, and you use the stock intake, and its not injecting a chemical like nitrous, your just using Gods good air and delivering it different than gm though about when they designed the car. Your really just altering air flow..right.
Honestly, if your all fired about going for the internet record and want to be able to lay claim to it without question then leave the heads/intake on the car just like it came from gm.
later...
owner of the fastest gm cranked, gm headed, small cubed, 6 speed formula on the internet that I know of.
Old Jan 14, 2010 | 01:48 PM
suicidal racing's Avatar
Originally Posted by GIZMO
They don't run EFI, because the rules do not allow it. It would add a huge increase in costs that only a few teams could afford to pay.
your talking about teams that have malti million doller engine programs...warren johnson did efi testing on pro stocks and they didnt make more power..nhra dont allow them vecause they cant regalate them..adrl could run them..and theres been tons of testing by gm and carbs make the power..also them carbs on them prostocks are around 12k .
tom thanks for the info
