LTX Shootout and 21* Trickflow heads
Old 01-13-2010, 08:02 PM
Tony Shepherd's Avatar
Default LTX Shootout and 21* Trickflow heads
I need some feedback on the Trickflow 21* heads. Some of us organizers are saying allow them and some say do not. On one hand it is only 2* which you can actually angle mill your stock heads to 21* and have the same thing so why not allow them? On the other hand...if we allow the trickflows other racers may ask.." you allowed those 21* heads why not my 18* Brodix.......etc". I know some street cars will have these bolt-on 21* Trickflows on their car.....we can't put them in Outlaw now can we? Get my drift????????? What do we do here? Allow them in Extreme Street and Modified...or not?
Old 01-13-2010, 08:08 PM
1badzee's Avatar
Is anyone running an 18* head in Outlaw? Just set the max at a 21* overall... Like you said, the factory heads can be angle milled to 21* anyway.
Old 01-13-2010, 08:09 PM
AChotrod's Avatar
I havent researched tham that much, but atleast let them in Mod.
I actually dont think any aftermarket head should be allowed in the EX classes, although I know others disagree with that.
So Im fine with it. If you can run AFR227s and a 408 w a SR then why not the TFS 21* heads.
Old 01-13-2010, 08:11 PM
JoeliusZ28's Avatar
227s will out perform them anyway, they are only a 185cc runner.
Old 01-13-2010, 08:14 PM
AChotrod's Avatar
Thats why I said let them in all classes. You can run a way more nasty combo and still be legal.
Old 01-13-2010, 08:16 PM
I agree. I think we should allow them . From what I remember the flow numbers where decent but will not outflow 23* AFR 227's. They may be comparable to the 195 and 210's. I will mention that to the others.
Old 01-13-2010, 08:36 PM
kgkern01's Avatar
Here are the flow specs as cast on the 21* TFS heads from Trickflow: https://ls1tech.com/forums/10495801-post26.html
As I recall AI claims getting nearly identical results when they flow tested the heads as cast as well.
Old 01-13-2010, 08:42 PM
1badzee's Avatar
Are you guys still going to discuss it or was the final verdict posted in here already?
Old 01-13-2010, 08:50 PM
Still discussing.
Old 01-13-2010, 09:30 PM
TravisMcGill2000's Avatar
i vote to let them run. but im also one of the ppl going to be using them.lol
Old 01-13-2010, 09:41 PM
1993 z28 f1's Avatar
Hey:
I say allow them in both ex and mod, I doubt they will make much difference on the cars that have them, than the other choices that are out there. It takes a lot more than a 2 degree head diff to make a significant advantage on something you can do to a stock head, 18* are a whole different story. Good luck on your choice hopefully it makes the most folks happy whatever way you choose.
Dub
When In Doubt Do Without
Old 01-13-2010, 10:04 PM
OutlawZ's Avatar
I say allow them.... 227's will kill them anyways..... hell allow them in outlaw!!!! if you're using them in Outlaw and you are competitive you deserve a trophy...
Old 01-13-2010, 10:12 PM
Puck's Avatar
I see no problem with allowing the 21* TFS heads - the big lure of them is for mild builds keeping CR up anyway, as a kind of bolt-on deal. I would imagine most of the really serious builds will be using max ported AFRs or converted SBC stuff anyway.
Old 01-13-2010, 10:45 PM
Colin91Z's Avatar
I say allow them. I mean afterall, they are a bolt-on LT1 specific head, and I don't see 2* making an unfair advantage over other LTx specific offerings that would be found on cars that qualify for EX street or Mod classes.
If someone wants to argue about the 18* heads, simply put, they are not a bolt-on deal AFAIK. Heads like that belong in Outlaw IMO.
Old 01-13-2010, 11:04 PM
95 Formula's Avatar
I say allow them but discuss if your gonna put a weight penalty on them or not. I'm really feeling like an underdog running gm lt4 heads with all this talk of 21 deg heads, 227s, etc...ha..
Old 01-13-2010, 11:06 PM
1 Craz28's Avatar
What about the little guys like me who have'nt taken there heads off yet?
Old 01-13-2010, 11:09 PM
95 Formula's Avatar
extreme NA is there for the taking. I def. think these heads(21 deg) should be for Modified and above only.
Old 01-13-2010, 11:21 PM
JoeliusZ28's Avatar
whys that? Id like to see them in the street extreme class too, even if at a penalty. I plan on running them in the future but my car will never be a 9 second drag car. Mid 11s is about as fast as im ever gonna go.
Old 01-13-2010, 11:29 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
i agree with Tim. mod. i don't think it is fair to the extreme guys. i mean if you are buying tfs heads, aren't you going to have them at least cleaned up prior to installing them? and they are 21 degrees.
you asked i answered.
Old 01-13-2010, 11:32 PM
95 Formula's Avatar
For the simple reason that the line has to be drawn somewhere. If not then why not let converted intake cars in if they meet all the other rules, why not let 3 speed trannys in if they meet all the other rules. There simply needs to be a "breaking point" where you have to move to the next class. Honestly, you can easily hit your goals without having to go that that head anyway.
Quick Reply: LTX Shootout and 21* Trickflow heads
