engine internals
Old Jan 14, 2010 | 12:57 PM
speedracer2536's Avatar
Default engine internals
ok so i bought a roller z28 that im putting back together.. i keep hearing about a reluctor wheel that goes infront of the crank gear.. i have a 97 front cover.. what crank hub and or reluctor wheel do i need
parts i have so far.
crank
rods
pistons
piston rings
gasket set
intake manifold
heads
block
cam bearings
valve covers
timming set
main bearings
rod bearings
freeze plugs
arp rod bolts
lifter dog bones
lifter hold down tray
pushrods
96-97 timming cover
cc306 cam
parts i know i need
roller rockers
valve springs
oil pan
oil pump
what other parts do i need that i am leaving off
Old Jan 14, 2010 | 02:05 PM
the_merv's Avatar
What year is this Z28..?
Old Jan 14, 2010 | 02:14 PM
its a 94 z28 obd1 but im going with a vented opti the cam that i bought has the longer dowel as well.
Old Jan 14, 2010 | 02:19 PM
the_merv's Avatar
Ok..well you don't need the Reluctor crap or the Cover with the Sensor on it. Since you have it you can use it, but you just have to install the Sensor so you don't throw Oil everywhere. If you can trade for a 1995 Cover do that..if not just install the Sensor.
Old Jan 14, 2010 | 02:24 PM
ya mine has the sensor.. so just leave that installed in the cover right? other than that what other parts can you see that i need to throw this thing together.
Old Jan 14, 2010 | 02:29 PM
the_merv's Avatar
You have the Oil Pump Drive Shaft(get the Melling one from O'Riellys) and the little Drive Gear for that? How bout the Water Pump Drive Shaft & Gear that sits behind the Timing Gear?
Old Jan 14, 2010 | 02:41 PM
i do not have the oil pump drive gear i do have the drive shaft for it though i do have the water pump stuff as well
Old Jan 15, 2010 | 06:05 PM
to the top.. is there anything else im forgetting to slap this thing together
