Motor is out! well almost... PICS
I would also lower it since the front suspension is out . Also the rears springs take
20 mins to swap out
You will need new struts for the front because the nut on the
top of the strut assembly is rusted on (typical Fbody problem) and the original struts
dont like to have dropped springs on them .
20 mins to swap out
You will need new struts for the front because the nut on thetop of the strut assembly is rusted on (typical Fbody problem) and the original struts
Also I would paint your Intake manifold a color of your choice . Red aka LT4 style
although common still looks very nice ! Black with the fins polished up also looks
killer ! What is the specs on your Head/Cam combo your gonna go with ? What
pushrods , lifters , Rockers , springs you goin with also ?
How many miles on this motor? While it was out, I'd have the heads freshened up at a decent shop (if not a head/cam/intake job from like Advanced...) Confirm the valve spring pressure, get a good cam and a set of Cometic head gaskets. Good timing chain....
It says FORMULA V8, just like every other formula, and what do you mean by loose suspension? Of course it looks loose, its not supported by anything at the top when the k-member is sitting on the ground...
actually only 93 and 94 cars say "formula V8"...95-97 Formulas just say "Formula" and 98-02 they did away with the bumper/DS headlight decals completely.
Really? I knew they did away with the bumper and headlight stickers on the LS1 body, but I could have sworn my buddies old 96 formula said "FORMULA V8" on it. It has been about 4 years since I last saw that car though.
I can`t remember what kind of markings are on a stock cam, been a long time since I`ve seen one. However, aftermarket cams will have #`s inscribed on the snout. Take a clear picture of the snout of the cam so we can verify what you have. Chances are if you don`t know, since you drove the car, you don`t have an aftermarket larger cam.
Don`t pay attention to 1 Craz28...He has the dumdum disease
I just sold a 97 Formula and it only said formula on the rear bumper same with the 96s!
