LT1 with TH400?
Old Jan 24, 2010 | 07:35 AM
  #81
ADM's Avatar
ADM
Originally Posted by Wicked94Z
3.73s would be a good match to a 3500 stall IMO. Don't count on getting anything close to good gas mileage around town, lol especially when you swap a carb on there
Fuel cost is the least of our worries here. Top up the Z28 with 92 octane for no more than 18$
Old Jan 24, 2010 | 12:45 PM
  #82
SS MPSTR's Avatar
Originally Posted by n2ocamaro
I paid $400 for a PTC nitrous converter.
You got a good deal. The nice Coan's are $900. A good converter ain't cheap!
Old Jan 24, 2010 | 02:02 PM
  #83
1mean96ss's Avatar
On th400's there is a delay when shifting simply because the motor has to produce more line pressure for the trans. I drove my friends monte carlo, small black 400 and a th400. Under WOT you have to shift a little below what you what, so once the trans builds pressure it shifts about 200 rpm more than what you intially shifted at. I would go th350 when you shift it shifts.
Old Jan 24, 2010 | 08:48 PM
  #84
ADM's Avatar
ADM
Would a shift kit not fix that?
Old Mar 4, 2010 | 01:13 AM
  #85
suicidal racing's Avatar
Originally Posted by 86formula
TH400 swap? 4300 installed with a trans brake, 2 step, Hurst piston grip, and install. thats a built TH400 too
did you get a kiss after you got fucked?..1500 tops and thats with a built th400 and everything else..including stall
im about to do a th350 swap..lets just say ill have alittle over 600$ into it before selling my 4l60...thats counting b&m 1/4 stick shifter,hughs 4500 stall,used th350 and bmr trans an tq arm mount
Old Mar 4, 2010 | 02:10 AM
  #86
Wicked94Z's Avatar
i wouldn't say 1500 with a converter and built trans is top quality... but to each their own. I would say 4300 is pretty high, but then again that's having someone else do the install.
Old Mar 4, 2010 | 02:54 AM
  #87
yes it would be..you can get a good converter for 400$ or so..and then factor in the 100$ for core from junk yard..then clutchs,sprag,vb and input shaft..if your going to put down over 800rwhp you should just switch to a glide..you will run faster on the track..an you can just swap to a harden imput shaft,good clutchs and run low 8s high 7s..
