LT1 with TH400?
What changes would I need to make to my car to be able to swap it in?
With a dead opti, I might even finally make the jump to carb along with the transmission swap.
What stall would go well with my CC503?
you will need a bigger stall then you probably have, atleast a 4k and what gearing do you have already.
You will need a differ driveshaft, new crossmember with or with out a tq arm relocation bracket.
Yea you would think so but if the frame is tweaked alittle or something isnt lined up right the drive shaft would be alittle longer or shorter. Also with different rear ends the drive shaft would change from car to car. Its one of those things you will have to get custom made anyways so why not wait to measure and double check yourself you know. I agree with you though they should all be pretty much the same I am sure you read this but here it is anyways.
Driveshaft-
In most cases the stock driveshaft will need modified. You can buy an aftermarket DS from many vendors online. Or just take you stock one to a local DS shop with the measurments and they will cut it for you. Driveshaft lengths will vary from car to car depending on a couple factors. If the car is using a 12 bolt or a 9" you will see some variances. Also, if you are using different types of motor mounts compared to others (stock, solid, poly or motorplate). It is best to measure the driveshaft for your application.
TH350 with a 9'' tailshaft will work with the stock DS
see Dennys drive shaft for info on measuring
The swap is really easy if you have everything to do it. It will be even easier since you are already auto. I did it from M6 so I had to change out the pedals shifter run cooler lines all thats stuff and it was still pretty easy to do. Word of advice dont short change yourself on the stall speed like I did at first go big the first time and enjoy.
