Lt1 specific n2o question. Which would or do you have on your car?
I have a post in the nitrous section already but wanted to see what you lt1 guys would do. I'm looking at these two kits. Post if you have one of them, have experience with them or any other insight.
Zex wet kit
http://www.summitracing.com/parts/CCA-82026/All/
HSW Dry Kit
http://www.harrisspeedworks.com/prod...?productid=356
Zex wet kit
HSW Dry Kit
http://www.nitrousoutlet.com/catalog...9&product=3042 plate kits are better than nozzle and dry kits
I had a HSW wet kit for a while. It was a crappy kit and I will never buy them again. My nozzle stripped out, my purge solenoid froze up all the time, and wouldn't purge, and my bottle heater switch never worked, they never would replace them. I even sent the switch into them, they tested it and said it worked fine, but when I installed it, the switch wouldn't work. The wiring was correct, when I would touch the two wires together that went to the switch, the heater would turn on. If you are going to buy a kit, go with Nitrous Outlet. Much better quality IMO.
another vote for nitrous outlet. Great people to buy from.
fyi....if you decide to go with a dry kit you need to be sure that your injectors are going to be able to provide the additional fuel needed to support the shot you want to run.
